Old 01-05-2014, 08:30 PM
CTRUEX CTRUEX is offline
Time for updates! The big brown truck brought me some 3/8 hydraulic line, ferrules, and nuts, so I got my lines bent up and installed. They're not as pretty as MTD's, but they will do the job. I also sat the freshly painted engine in, on the old mounts, and the dipstick tube was extended with an adapter, since the 2082's was way too tall. I'm going to do some more tonight and tomorrow, but now I'm waiting on the new motor mounts and a large Kubota parts order, among other things.
http://www.onlycubcadets.net/forum/a...1&d=1388971670
Old 01-05-2014, 08:52 PM
Looking good! Brown truck good!
Old 01-05-2014, 08:57 PM
What Mike said!
Old 01-05-2014, 09:01 PM
TIMCRUTCHER TIMCRUTCHER is offline
What they said! X3
Old 01-05-2014, 10:16 PM
Looking great!
Old 01-05-2014, 10:55 PM
Bburgerbc Bburgerbc is offline
J-mech I separated my front and rear hydraulics on my 1782. I bought a used cylinder like the one it comes with added a valve in the dash, and plumbed it. The added cylinder is mounted directly to the rock shaft in the back. I cut a hole in the frame rail in the back to allow cylinder room and made a box out in the frame with a piece of quarter inch wall square tube with end caps . The setup works great . Though it took time to figure it all out I'm really glad I did it
Old 01-06-2014, 07:34 AM
Looks good
Old 01-06-2014, 09:03 AM
cubfan's Avatar
cubfan cubfan is offline
Nothing like a good build project and getting to build them how you want them to be with all the goodies that make you happy.Great job.
Old 01-06-2014, 04:53 PM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Look'n good Cory... Hot coco with marshmallows
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 01-06-2014, 07:54 PM
ccguy's Avatar
ccguy ccguy is offline
Too nice CTRUEX! Really coming together! A complete transformation.
ccguy
Western MA
