Old 03-23-2010, 05:32 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Default Mower drive pulleys
Where can I buy the 2 pulleys and belts tightener for the mule drive?
Pat Benner Haskell OK
Old 03-23-2010, 05:38 PM
CBH's Avatar
CBH CBH is offline
I bought two new mule drive pulleys at a local shop that sells bearings, pulleys etc. They must be a common size. They had them in stock.
Old 03-23-2010, 05:55 PM
I am sure the sponsors at the top of this page would be more than happy & willing to help you out.
Old 03-23-2010, 06:10 PM
Does your local farm supply store have a pulley shelf ? The TSC stores seem to always stock every pulley you could need but one of you other cub owners grabs the last cub sized pulleys off the rack minutes before I arrive there...lol. Your local bearing wholesaler is also a good place to check.
The belt tightener can be made from a piece of all thread and a washer....Not that I have done that , of course..lol.
And as Roland says, the sponsors and your local CC dealers also may be able to help.
Old 03-23-2010, 06:30 PM
This is what can happen when one uses cheap cast or stamped steel mule drive pulleys....
Old 03-23-2010, 06:52 PM
Amigatec's Avatar
I would like to buy some good quality parts for this.
Also I see lot of owners have 2 tighteners on their drives, I have one and a spring, is it necessary to have 2 tighteners?
Old 03-23-2010, 08:58 PM
redwaycc's Avatar
redwaycc redwaycc is offline
yes, you need two tighteners if you are using a tiller. i fabricated one out of 1/4" plate and a good quality 5/16" bolt, fender washer, normal washer and installed that in the big hole next to the spring hole. there is a "step/slotted" tightener but it will not work on your mule drive if you dont have that slot on the right(spring) side.
you will find reference to both the solid pulley and tightener in the tiller manual in the tech library.
100(2) 128, 129, 76(1/2)
