Old 01-14-2014, 01:12 PM
gophred's Avatar
gophred gophred is offline
Default Broken zerk fitting on deck spindle
I have a 44A deck and one of the zerk fittings on an outside spindle is broken. It appears to be pressed in (and is not listed separate on the fiche). I found a thread on busted zerks in the front end saying to to remove the sleeve and pound them in. If I pound it in, I am not sure I will be able to recover the broken peice out of the spindle (I have never been inside the spindle assy)
Thanks
Gophred
2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower.
Old 01-14-2014, 02:35 PM
Drill it out, tap the hole and put a threaded one in.
Old 01-14-2014, 04:15 PM
sawdustdad's Avatar
What is the best way to avoid getting metal shavings down in the hole when you do this? Any tricks?
Old 01-14-2014, 04:21 PM
jimbob200521's Avatar
What's always worked for me is coating the drill bit in grease then doing a revolution or two at a time. The shavings have always stuck to the drill bit/grease for me.
-Ryan
Old 01-14-2014, 04:51 PM
Old 01-14-2014, 06:52 PM
Just my 2 cents but I would remove the shaft, drill out the broken zerk tap it for a screw in zerk, pump some grease through it then reassemble it. One little chip will trash a bearing.
Old 01-14-2014, 10:24 PM
gophred's Avatar
so are you saying you would press off the bearings? I tore it down to the spindle/bearings. tomorrow I can get it on a press, but I was debating if I wanted to try pressing them off. The bearings feel OK, but look really rough and there was a lot of rust in the cup
Gophred
Old 01-14-2014, 10:30 PM
If the bearings do NOT have a perfect finish on the surface, they are junk. Any imperfection will cause failure. They are a precision component.
Old 01-14-2014, 11:41 PM
They're junk.
Old 01-14-2014, 11:55 PM
gophred's Avatar
I see now that they are not serviceable. Time to . Tomorrow I am going to drill out the broken zerk tap it and hopefully get a new fitting in. Then blast everything else grease it all and reassemble and see what happens. This is a camp mower, maybe I can get a season or 2 out of it
thanks for the help
Gophred
