Old 01-15-2014, 06:57 PM
nikster's Avatar
nikster nikster is offline
Originally Posted by DoubleO7 View Post
The vibrations seem to kill all of those hoods at the pivot points.
If you find one that is not cracked or wallered out there, it soon will be after xx hours.
Maybe just weld a thick washer over the hole and save the one you have.
That's the exact problem I have. A true flaw in manufacturing.
I've inquired to a few & . The cost of the hood is crazy, then with shipping, is crazier. Be darned if I'm gonna pay 1/3 the cost of the entire machine.
Looks as if my 90amp welder will do a little welding this spring.
NIK,
Old 01-15-2014, 06:59 PM
nikster's Avatar
Originally Posted by dbuck View Post
On my 127, i cut out the damaged section and tig welded in new sheet metal and then tig welded a thick washer over the new sheet metal and it works just fine.
great idea, might attempt something like that?
NIK,
Old 01-15-2014, 11:03 PM
MinnesotaCadet's Avatar
I've got a hood from a 147, Its in very good shape. PM if your interested, I know shipping wasn't cheap though. I can post some pictures.
Connor
Old 01-16-2014, 05:45 PM
nikster's Avatar
I sent you a pm with my phone number,
Nik
Old 01-17-2014, 07:46 AM
dbuck dbuck is offline
Smile
NIK,
I have a Buddy with a sheet metal shop. Took the hood over to him and he copied the damaged area, 1/2 hr later I was out the door with the new pieces. Drilled out the nose piece and pressed brass bushing in, reamed the bushing to size and its been working good ever since.
Old 01-17-2014, 10:08 AM
nikster's Avatar
Well by your description it seems like a good job. But if possible is a close-up picavailable? My feeble mind is NOT capable of trying to visualize what you mean? Im not that mechanically inclined, but I try.
MinnesotaCadet has graciously offer a real nice hood from a # 147. In the process of POSSIBLY buying it? We are working on a price. One good thing is that both of us has a fastenall dealer nearby for shipping, just got to go over there to estimate shipping cost.
But if I do purchase it I want to re-enforce that WEAK pivot point with some type of bushing to make it work as bduck described.
Nik
Old 01-18-2014, 10:19 AM
Smile
Sorry not picture savy. The reason for the bushing in the nose piece is, the hole was wallered out. Drilled the hole out to .002 under sized of the bushing O.D. Pressed the bushing in and then reamed the bushing to the bolt O.D. Not doing this and the nose piece hole wallered out it would have been worthless to repair the hood. Good luck in your endevers.
Old 01-18-2014, 04:52 PM
nikster's Avatar
Thank you,
As it turns out I struck a deal with minnesotaCub. For a hood.
Thank you----- MinnesotaCub,
NIK.
Old 01-18-2014, 10:19 PM
Glad you found a hood!
Old 01-19-2014, 10:10 AM
Thumbs up
You are Welcome. Ditto on what ACecil posted.
