Old 01-15-2014, 01:44 PM
bigdaddyjak bigdaddyjak is offline
Default Snow thrower belt tension
On the qa36a, does it make sense to tighten the 4 carriage bolts down tight after you've got the belt tensioned tight, that way it prevents it from loosening up at all??
To much to list!
Old 01-15-2014, 02:14 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default snow thrower belt tension
I have the same question,but for a qa36. Looking forward to the answer.
Old 01-15-2014, 03:08 PM
cubby102's Avatar
cubby102 cubby102 is offline
I always have
Old 01-15-2014, 08:37 PM
the qa 36a .You do not have to loosen the bolts.
On a qa 42 you do not have to loosen the bolts.
Read up on the manual.
Old 01-16-2014, 07:03 PM
There r actually bushings around each bolt, this is suppose to make it so tension can be set on the belt and and u cannot immobilize the plate. Just looked like my plate was moving during operation. But hey, it's in the manual
To much to list!
Old 01-16-2014, 07:09 PM
I have been using mine for the last 4 yrs without any big problems, besides loosing a belt occasionally. But this yr, it just would work without throwing belts. A few yrs ago, I drilled a hole next to the tensioner handle, put a .25" bolt in, so it can't loosen up. I put a new shiv on, .5x3". It works great now
To much to list!
Old 01-18-2014, 05:47 PM
Wheelie Wheelie is offline
1/15/14 wheelie. I have a cc105 with a qa36 and need a new belt do you know the number
Of the belt?
Regards
Wheelie
Old 01-18-2014, 06:16 PM
Of the belt?
Regards
Wheelie
Parts Tree says it's a Cub Cadet 487043-R1
Old 01-19-2014, 09:12 AM
Default Qa36 Beltran
From wheelie, thanks for your response to my question for a qa36 belt. It was
Helpful.
Regards,
Wheelie from rhode island
