Old 01-20-2014, 10:50 PM
rockyj82 rockyj82 is offline
Default Not enough room for tire chains on my HDS3225! Help!
Ok guys here is the problem I have a hds3225 it is a great tractor however I went to install a set of chains on it only to realize that there is not enough clearance between the "wings" on the fuel tank and the top of the tire it also looks like the tolerance is pretty close between the inside of the fender well and the side of the tire. The tires that are on the tractor now are the factory size at 24x10.5x12. I have noticed that you cannot even find that size anymore. Has anyone else run into this problem and does anyone have a tire size that they run on their 3225 that will fit chains. I have looked at either 23x10.5x12 or even a 23x9.5x12 but I was wondering if they would fit my factory rims with no problems. Any help would be much appreciated. Thanks
1450 Cub hydro sleeve hitch
50a Mower Deck
42" Snow Blade
Single Bottom Plow
42" Snow Thrower
Old 01-20-2014, 11:29 PM
Quick tire lesson. On these tires, the first number represents the overall height of the tire. Second number the width, and the third the rim size diameter. All numbers in inches. So, a 23-10.50X12 will fit, and assuming the rim is 8.50" wide, (there's a good chance it is) you can go down to a 23-8.50X12. The narrower you go, the shorter the tire will be because it has to spread out to accommodate the rim. Tires are usually mounted on a narrower than they are rim. If you want less "ballooning" you run a narrower tire on a wider rim and so on. (Hope that makes sense.) So, there are a lot of different sizes that will go on that rim, and if you go to a 23-10.50X12 instead of a 24 it will get you a little clearance. If you go to a 23-8.50X12 it will give you more. Most of us here have older cubs, maybe there will be someone on here who has put chains on one of these. As far as what to go with, I don't know.
Old 01-21-2014, 06:38 AM
ccpullin ccpullin is offline
Cub Cadet knew of a issue shortly after release for a too close to the frame and was replacing these wheels at no charge at that time with offset ones. I do not know if they still have that program. Now this dose not effect the height of the tire chains rubbing, just the inside clearance. You may try cables or a lower profile tire as mentioned.
Old 01-21-2014, 08:16 AM
http://www.millertire.com/categories/lawn-garden-tires/
Maybe you could use something like a 23 X 9.5 X 12 turf on it with chains. I'd call Miller and try to find out what they think.
EDIT
Call Patton or Cub Classics and find out if the have a set of wheels and tires off something like a 2135, they are 20 X 9 X 8 pretty sure they would bolt on your tractor.
Old 01-21-2014, 11:30 AM
Thanks guys that helps alot. Everyone is always a big help on this forum. Special thanks to JMECH, I was pretty sure that is how the tires were listed. I am thinking that I have 8.5 inch rims also. CCPULLEN, I had heard that rumor also however the local cub dealer didnt know and wasnt really interested in finding out. LOL. SAM MAC I will check into the miller website looks like they are a little cheaper for the tire just have to check on the shipping prices, I had found a website that was pretty helpful also with the sizes because it gave the actual dimensions when it was mounted on the rim. I was looking at these
http://www.petestirestore.com/Carlis...-Ply-p672.html
The only thing that concerned me was when I went below a 10.5 inch wide tire the web site said the recomended they be mounted on a 7" wide rim. Can I mount a 9.5" tire on a 8.5" rim? I am also assuming that the dimensions listed on the website would be wrong if I did mount it on a wider rim because the tire would be shorter and more spread out? Thanks again for all the help.
50a Mower Deck
42" Snow Blade
Single Bottom Plow
42" Snow Thrower
Old 01-21-2014, 12:03 PM
You should be able to get the 9-1/2" tire on an 8-1/2" rim you may want to go with tubes also. I'm not sure that these will be small enough to allow you to get chains on. They have a 23.6" OD. Just my 2 cents but I'd look for a set of used wheels and tires of something like a 2135, put chains on them and just keep them for winter work. Fill them with rim guard and hang some weights off the back of the tractor. These should be around a 19.5" OD.
Old 01-21-2014, 12:16 PM
cubs-n-bxrs's Avatar
To bad you didn't live closer. I have a set of turf tires and rims that came off of a 2185 that I would give you just to get them out of my hair. They are 4 bolt pattern and are 23x9.5x12.
Old 01-21-2014, 12:58 PM
Workinprogress Workinprogress is offline
Any thoughts about creating a metal spacer plate that would be mounted between the rim and the tractor hub? Not sure if the shift would give you enough space.
Old 01-21-2014, 06:20 PM
IH Cub Cadet IH Cub Cadet is offline
You can buy spacers to move the tire/rim out. This is a common problem with some garden tractors. My IH 1650 is in need of some spacers for chain clearance.
Here is a link to some spacers:
http://www.xtrememotorworks.com/Part...rts%20List.htm
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 01-21-2014, 10:27 PM
Rocky, here are a few pics of my 1999 built 3205. It looks like I have around 2" of clearence. I don't know if that is enough because chains are illegal here in Georgia on a tractor. If it snows here you stay home. It looks like my wheel has about 4.5" of offset from the front...if that is what you call that measurement. These are the original tires and rims as far as I know. Looks like I'm missing a lug nut too.
