I just used a 1/2" x 2 1/2" grade 8 bolt ground to fit in a dampener washer from an IH truck and a 2" doughnut gasket all welded up and ready to go. Should last way longer than the original. Just stuff I had laying around.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
Good idea.
Good job!
Nice idea!
Nice! Start mass producing them?
NIK. I'm in awe of some of the thingies that guys produce on this site.
It dont cut grass, but its yellow. |
Late 50's and early 60's Chrysler products have huge cupped washers on the strut rods (2 ea) that are perfect for this use also.
yesmar 34 what is the donut gasket material?
If he was able to weld it to steel my guess is that it's steel.
I kinda figured BUT I've never saw one other then fiber impregnated with steel therefor the dumb question I should of asked pure steel?
Yes they are made from steel of course. They are used on exhaust systems on cars and trucks. This one is NOS from parts I have saved up for my 2 IH pick-ups. ( see my avatar) Some of these parts for old IH trucks are getting scarce. Although these gaskets were used on lots of vehicles, not just IH. They go between the exhaust manifold and the cross-over pipe. They are flat on the manifold side and chamfered on the other side to wedge tight into the bell end of the cross-over pipe when you tighten them down. We just always called them doughnut gaskets. This worked perfect around the dampener washer, also NOS.
Thanks for all the thumbs up.
