Old 03-12-2013, 09:28 PM
I filled both of these 26X12X12's in about 5 miutes
Old 03-12-2013, 10:42 PM
cubby102's Avatar
cubby102 cubby102 is offline
With the 850s I filled with washer.fluid and had tubes I took.the valve core out screwed on a old piece.of fuel line and used.a old.fuel.tank.I.had would pressurized the.tank.with my air compressor through a small hole I.drilled in.the.cap. took me maybe 20 minutes for both tires. My tubeless 10.50 s I just broke the valve.stem side of the bead and filled it.with 7 gallons then aired.it back up. Works good.and easy
Old 03-13-2013, 12:10 AM
Down her in Georgia I use H2O only in tubes. Some guys add dish soap to increase the freeze point. I don't think that will work up in good ole PA.
Old 03-13-2013, 01:38 AM
macman81's Avatar
macman81 macman81 is offline
i have one tractor that came with green antifreeze in the tires, and i put in purple washer fluid. i ALWAYS tube my tires when i have them apart and have never had a flat since. i pump the washer fluid in with the cheapest electric fuel pump i could find. i think its a used one off a chevy diesel. its a little slow but works good and isnt messy to do. i got 7 gallons in per side.
on my snow blade rig i have fluid plus 5o lb wheel weights on each side and its barely enough when the snow is wet.
to each their own i guess.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 03-13-2013, 07:37 AM
steveyrock's Avatar
steveyrock steveyrock is offline
I put innertubes in a set of 10.5x23s got whole shopping cart full of washer fluid at wal mart when it was on sale for 99 cents a gallon.
I took a pump weed sprayer and removed the wand and clamped the hose from it to the valve stem after removeing the shrader valve from the innertube. I simply filled the sprayer and pumped the fluid in with the tire and wheel laying on it's side. 14 GALLONS DID BOTH TIRES,on a bathroom scale they weighed near 50 lbs I threw a wheel weight on the scale and that brought one set to 80 lbs with chains on tire. Did that 4 yrs ago and never any leaks or froze fluid.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 03-13-2013, 06:15 PM
ironman's Avatar
ironman ironman is offline
I just bought a set of new Deestone 23 x 10.50/12's on eBay from Greater Cleaveland Tire (gregthree) for $121 plus 20 bucks for shipping. He claims they are 6 ply. Is that an ok price or could I have done better. Now gotta sandblast & paint rims, then go fluid shopping. The fun never ends.
Old 03-19-2013, 08:14 PM
Chevyguy Chevyguy is offline
Smile E-Z way to fill tires
I removed the hose and wand from my 2 gallon garden sprayer, put a 2' long piece of 5/16 rubber fuel hose over the nipple on the sprayer and slid the other end of the hose over the valve stem after removing the schrader valve. Turn the wheel so the valve stem is positioned at the top. Fill the sprayer with WWF, install the hand pump in the sprayer and give it about 20 pumps. The pressure in the sprayer will force the fluid into the tire. You will have to pump some more to keep the pressure up in the sprayer. When you remove the pump from the sprayer the excess air will bleed out of the tire while you refill the sprayer. I filled 2 23-10.50-12 tires with 12 gallons of WWF in about 30 minutes.
Old 01-25-2014, 04:24 PM
I just filled a set of 26 X 12 x12's with a little pump I had laying around. It's a Flo Jet pump that I used to have on my race car to pump tranny fluid to a cooler. It's 12 volt but I also have a 12 volt power supply. Normally I take the tires to the local tire shop and have them break the bead on the valve stem side as I've mentioned before but I will need to fill a set of tires on my 121 that have tubes so I figured I'd try this pump and see how it did on the big rubber. Had the hoses kind of jury rigged but it went well. Just pulled the valve cores out and slid the 3/8" hose ove the stem and let it rip. I let the air out of the tire after every gal. I may get one of those tire fillers that TSC sells and make up something a little more permanent for the future. Anyway I put 8 gals in each tire probably took 20 mins.
