I know this has nothing to do with Cubs but thought some of you guys would find it interesting.
Specs are: A 42 cylinder radial with 8757 cubic inches of Russian Origin (Zvesda/St. Petersburg) 42 cylinders heptagonal-star/6 cylinder rows Diameter 160 mm, stroke 170 mm, capacity: 143500 ccm (8757 cu in) 7 over head camshafts driven by shafts, central steer time adjustment 4 valves/cylinder, 168 valves operated by roller rocker arms one cam moves an exhaust valve and an inlet valve Rotational speed: up to a maximum of 2500 rpm Torque: about 15000 Nm (approx 11063 ft/lb) Power: about 4500 kW (approx 6034 hp) Fuel consumption: 205 g/kWh resp. About 800 liters diesel/h Direct injection 9-hole injectors Decentralized fuel injection pump, per cylinder p ~ 1.000 bar Turbo compound: 1 step axial turbine and 1 step radial blower (p ~ 2,1 bar) Joined with crankshaft via 3 parallel hydrodynamic couplings Compressed air start system is at work with 150 bar compressed air on 2 cylinder banks (12 cylinders) Dimensions: diameter 1.600 mm, length ~ 2.000 mm"
Big Muther is right Sam! Wow!
Not your grandads 1 cylinder kohler.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
That's a monster!
Big Ole engine!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Very cool, I'd hate to have to adjust the valves on that beast. In the video it pulled that load with little effort, and the tires were nearly slicks.
Mike |
Just out of curiosity, I'd like to see that dragging across the salt flats in Utah. I wonder how far it would pull before any damage occurred.
