Old 01-27-2014, 07:32 PM
Just a couple tips from someone that has BTDT just get a hole punched through it on the first pass, then take a nibble at a time on the next passes. Since you don't have chains on the 782 don't be afraid to ram the snow. Have fun Buddy. If it's wet and heavy you may want to have at it when you get about 3" and then every 3" or so. Or you can wait till it melts the next day in your area.
Oh, and don't bust your frame like Nick did! (Just teasing you Nick!!) Remember to unlatch the spring trip!
Old 01-27-2014, 08:19 PM
Angry
When my late Dad moved down to NC from PA, the thing that humored him most was the "snow attitude".
They said " God brought it, God will take it away"
Lol thanks Jonathan.
Old 01-27-2014, 08:30 PM
jimbob200521's Avatar
Good luck on getting some white stuff!
-Ryan
Old 01-27-2014, 08:44 PM
Thanks guys! The blade is now touching the ground like it should. I took the height adjustment knob off, and that fixed the problem. Now I'm ready for the white stuff!
Old 01-28-2014, 06:05 AM
Thanks guys! The blade is now touching the ground like it should. I took the height adjustment know off, and that fixed the problem. Now I'm ready for the white stuff!
Good to hear Allen!
Old 01-28-2014, 06:31 AM
Glad it's ready Allen.
Old 01-28-2014, 10:52 AM
1811woody's Avatar
Allen Nice plow setup! If you want more practice plowing for snow you can plow your leaves or you can haul your rig out this way theres lots of snow to be plowed.
I wondered why you had to take the adjuster knob off for it to touch the ground isn't the lift rod long enough?
Old 01-28-2014, 11:29 AM
Thanks! I'm not sure why I had to take the knob off. The lift rod is 29", so it's long enough. Next time the 782 is out, I'm going to see if it's lifting the blade higher.
Old 01-28-2014, 12:32 PM
AC
Any snow down your way yet? We are getting a light dusting at the moment up here in Galax VA.
Old 01-28-2014, 01:13 PM
AC
I was wondering the same thing? When you supposed to start getting snow Allen?
