Old 02-05-2014, 03:48 PM
Originally Posted by Cubby guy View Post
I see more of the older Cub Cadets still being used that I see of ANY Other brand, new models or older units.
My Cub Cadet is a 1976 model 800. This winter, I am doing more maintenance than I have done before, I have pulled the spindles out of the 38A deck to clean and relube them and sharpen blades. A LOT of grease had become dry and chunky inside the spindle cup assemblies, making for rough operation.
I'll find out in a couple of months, when I put it all back together.
The most rare cub out there, a coveted prize...... and you MOW WITH IT???
I'd restore it and get another cub to mow with. But hey, it's your tractor!! I'm happy for you!
Old 02-05-2014, 04:37 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Winter Storm Maximus, SE Pennsylvania, Feb. 3, 2014.
Model 149 with QA-42-A Snow Thrower in 8-inches of heavy wet snow...no problem.
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 02-05-2014, 05:24 PM
[QUOTE=J-Mech;241406]The most rare cub out there, a coveted prize...... and you MOW WITH IT???
Jonathan, my Cub gets mad if I don't mow the yard at least once a week with it. It even sulks if I have to get something else in the barn and don't bring it out to play.
Only thing better than having a Cub Cadet is USING one
Old 02-05-2014, 05:30 PM
As much as I hate to admit it, I don't recommend that anyone abuse their hydros the way my Brother and I abuse mine.
Quite frankly, I've been slamming my hydros from forward to reverse and back again for YEARS. Normally, when I get them, I pressure wash the years of crud off of them, repair the trunnion, clean the release valves, and change the fluid and filter. Then they are all set for a good many years of abuse.
If you use yours like a person with good sense, it should last your lifetime, your children's lifetime and your grandchildren's. I wouldn't ever worry about "working" one too hard.
Old 02-05-2014, 05:38 PM
[QUOTE=Cubby guy;241426]
I'm sure if I ever find one, I'd use it too. Collector or not. It's not like your going to hurt it.
You too?
Old 02-05-2014, 05:46 PM
Something else, I inherited the 800 from my dad. He bought it in 1976 after he retired from IH. Until he passed on, he used it to mow his yard, plus two Church lawn areas.
Neither one of my brothers wanted it, so I said ( more like shouted from the rooftops ) " I WANT THE CUB CADET! ! !
Old 02-05-2014, 06:56 PM
jimbob200521's Avatar
You too?
Phew, good to know there's other out there like me!
-Ryan
Old 02-05-2014, 07:15 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I've been plowing this year with my 129 and it has done a good job. I think I need more weight on the rear. It's only got 35 lb weights on it. I get a good bit of wheel spin. I guess I should chain up too. I should have my 782 ready for next winter.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 02-05-2014, 07:56 PM
I hope not...if so I've got a long winter ahead of me.....
I'd be more concerned about engine durability/life running the winter we have with a front mounted thrower.
Old 02-05-2014, 08:06 PM
do you have any picture of your 800?
