Old 01-25-2014, 09:50 AM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Thumbs up
Thanks guys for the info, it gives me something to go off of now.
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 01-25-2014, 04:50 PM
dirtcowboy's Avatar
My landslide is long and runs up under the shear. If i take the landslide off is that going to hurt the shear when plowing. It looks like it reenforces the shear. The landslide looks like it will come off easy with undoing 3 bolts but i want to make sure before i do this if this is what your talking about.
Old 01-26-2014, 02:56 AM
Post a pic. I don't have my plow where I can get to it to look. I think someone made the tail on yours. It may not be separate. May have to make a piece to go in it's place.... only shorter.
Old 01-26-2014, 09:44 AM
Merk Merk is offline
Landslide is needed. It rides againet the furrow wall.
Project Uncle Dick
Cub Cadet 70
Old 01-26-2014, 03:43 PM
dirtcowboy's Avatar
My landslide is one long piece and is held on with 3 bolts. I checked a friends plow just like mine & his is the same as mine.
Old 01-26-2014, 04:04 PM
Yes, so you will have to make a shorter piece to go in it's place. Like Merk said, you have to have one...... just need to get rid on the long tail.
Old 02-06-2014, 07:07 PM
twostep's Avatar
twostep twostep is offline
The guy that makes and sells those on Ebay is Olcowhand, he can be found easily on the GTT forum.
http://gardentractortalk.com/forums/user/20-olcowhand/
