Old 02-14-2014, 10:54 AM
hdsdcouple's Avatar
Default Reverse Gears
On this cub 71 I have is there any way to put a faster reverse gear in these? or are we stuck with what it is.
Old 02-14-2014, 11:08 AM
jimbob200521's Avatar
I can't help with the answer, although I'd imagine it's a no, but what do you do so much in reverse that you want to go faster?
-Ryan
Old 02-14-2014, 12:22 PM
hdsdcouple's Avatar
Pushing snow, I have a lot of long passes. just gets to be a pain doing 3 point turns on both ends. I have a really wide drive and where I need to pile the snow is at one end. makes for 14 to 20 passes about 100 foot long. so backing up gets annoying.
Old 02-14-2014, 01:06 PM
Turn around and wind-row it over one pass so you aren't wasting time. Or buy a blower.
Old 02-14-2014, 01:27 PM
cubs-n-bxrs's Avatar
Hydro with a cab and blower is the only way to go doing snow removal. Gear drives are just a real pain in the butt. Waste to much time shifting.
Old 02-14-2014, 01:35 PM
Yep!
Old 02-14-2014, 01:36 PM
As true as that is, I can't completely agree I did the first half of this years snow removal on a gear drive Cub Cadet and something about shifting gears makes it...fun!! But for practicality purposes, yes, a hydro is the way to go (especially if you have a lot to clean up).
-Ryan
Old 02-14-2014, 02:50 PM
Yup, this is exactly why I can't live without my hydro or gear drive Cubs.
I understand that not everyone can own multiple Cubs, but if you have a hydro you probably really need a gear drive too... and vice-versa.
As much of a pain as it is, sometimes when I push snow, I do get off at the end of each row and turn the blade the other way.
I also kinda think that in many situations, when pushing snow, you gotta dig a hole at each end first so you have a place to turn around, it's just part of the deal.
Don't be fooled! Slamming a hydro from forward to reverse and back again is about the most fun you can have (with all your winter clothes on).
Old 02-14-2014, 02:54 PM
And if you do it right...... it doesn't take much room to turn them around.
Old 02-14-2014, 03:29 PM
hdsdcouple's Avatar
well if you turn around and wind row going both directions, then you have to get off and switch the blade angle. Not going to happen 28 times. And I use the gear shift tractor because it is fun. If I was worried about being quick about it I would just get in the truck and use the snow plow on that. I do it with the old 71 and the blade because it is a lot of fun. nothing more. and I have not got enough snow to justify the blower on it yet. and again if I get that much I use the truck plow. I like the snow and the tractor. nothing like 6am dark and plowing as the sun comes up. I like killing snow almost as much as killing grass. Nothing like man and machine off to kick mother natures butt.
so no on the faster reverse Gear?
