Old 08-28-2009, 11:03 PM
michcruiser60's Avatar
michcruiser60 michcruiser60 is offline
Default Guys help me out with a question.
I'm very new to Cub Cadets. I have a few questions about the Supers and some of the 82 series tractors.
Which ones (red or yellow) have the rear independent braking?
Is there a preference to internal or external brakes? Which is better?
I'm beginning to really like my Cub a bunch and may want to get another later on. I'd like to know what to look for next time around.
Mich60
If its got rust or dust on it... I'm into it.
1282 & 2166 Cubs
Old 08-29-2009, 12:43 AM
Most of the supers had the split brakes standard. I believe that it was an option on the 982 and possibly some of the other models before the 1872/2072 etc. were introduced.
Internal brakes allow you to put weights on the inside of the wheels. It's also easier to attach chains and wheel weights without the brake disc and caliper in the way. However, they don't hold as strong as the external brakes and are harder to adjust if the adjuster got rusty.
External brakes hold a bit better. They are no more expensive to reline than the internal brake if you know where to get the material, but are more labor-intensive. If you have external brakes, you at least have the option of installing independent pedals if you can fab them up. I made some for my 782. I prefer the external brakes on my 82 series tractors, as I'll be putting independent brakes on them all eventually.
Old 02-23-2014, 07:05 AM
yeeter yeeter is offline
An old thread but Matt: Can you share some pics (or a link) of converting to steering brakes on your 782?
Definitely something I would be interested in doing....
Old 02-23-2014, 07:25 AM
Matt got mad and left this forum quite a while back.
However, there are postings here that show how to make independent brakes on a standard GT. I am sure a search will bear you some fruit.
PS: This may help.... http://www.onlycubcadets.net/forum/showthread.php?t=20585&page=10
Old 02-23-2014, 08:28 AM
This is a link to Matt's page on how he did his conversion. Click on projects.
http://mgonitzke.net16.net/
Old 02-23-2014, 11:43 AM
Tony h's Avatar
Tony h Tony h is offline
Just checked on MATTS PROJECTS he shows the pedals but not how he created the two external brakes. The 782 has internal brakes. Not sure you can make independent brakes unless you add external discs and calipers first
If I can't fix it , it must not be broken
Old 02-23-2014, 12:00 PM
That is correct. He didn't "create" external brakes.... he USED external brakes. Yes, you have to do away with the internal.... or at least take the lever off, and put external brakes on it first.
Old 02-23-2014, 12:17 PM
MWShaw's Avatar
MWShaw MWShaw is offline
I looked at adding steering brakes to my 782, decided it was more hassle than it would be worth.
If you look at post #58, on this thread, you can see what I was looking at;
http://www.onlycubcadets.net/forum/s...t=17498&page=6
You can leave the internal brake alone and just add the external stuff. That's what I did on the 17/121 project. You'll need the pedal assembly from a Super and a set of calipers and disk's.
Read a few pages in this thread.
http://www.onlycubcadets.net/forum/s...=20585&page=10
Old 02-23-2014, 04:24 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
As soon as I find the pedal assembly im going to put turning brakes on the 582.
Doug
Original , 100 , 125 , 582
