Old 02-23-2014, 08:42 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I've had good luck using turbo sockets. Kroil does work very good
http://www.sears.com/search=turbo%20...urbo%20sockets
Old 02-24-2014, 02:35 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Originally Posted by Shaner View Post
like the others said, weld a washer then a nut to it...the heat should break it loose...but let it cool down a minute or so before you try to wrench on it, otherwise it will twist more of the stud right off.
I would do this also.
But I would let it cool and as soon as it does not boil the penetrating oil, put it on good and plenty.
I prefer to let it then cool to room temp in order to get the maximum shrinkage possible.
Then turn it out with a six point wrench/socket.
Old 02-25-2014, 03:30 PM
782CC 782CC is offline
x2
heat draws the penetrant in. And the heat swelling the bolt is part of the solution. Getting as cool (small bolt) as possible only enhances the chance of success.
