Old 02-26-2014, 03:16 PM
bill682 bill682 is offline
Default Wix Hydraulic Filter
I was using the Wix Filter Lookup to find the correct hydro filter for my 682. It shows 51084 but I'm not sure that is right because it has an anti drain back valve. Can anyone confirm if this is the correct filter?
http://www.wixfilters.com/Lookup/App...aspx?Section=4
Old 02-26-2014, 03:36 PM
This may help........... Hydro Oil Filters
Old 02-26-2014, 04:10 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Wix 51410 is the correct number. The 51084 is an engine oil filter. My grandfather put one on the 1811, who knows how long it was on there! No ill effects were caused. I replaced it after the driveshaft rubbed a hole in it
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-26-2014, 04:13 PM
The 51410 will work on all Cubs but was designed for the HG hydro's in the cyclops line, 2k &3k machines. The 51084 has the anti-drainback valve and works well on the older machines with the Sunstrand pumps but not on the newer machines with the HG pumps. The 51084 will keep the pump full of oil so on the next start up it doesn't start dry.
Old 02-26-2014, 04:25 PM
Good to know, thanks!
Old 02-26-2014, 05:28 PM
Thanks to Todd Markle.
Old 02-27-2014, 04:48 PM
I assume the new MTD filters have no anti-drainback valve. Do they have one for the older IH tractors or does it really not matter?
The Wix 51084 has a nut on the end like the original IH filters.
Old 02-27-2014, 05:51 PM
I respectfully disagree.
The 51410 is the correct Hydro Filter for the Sundstrand Hydro. It meets or exceeds Sundstrands and Cub Cadets specifications. About 4 years ago, a couple of us did an extensive search, bought and cut open several filters. The ones in the above chart are the only ones that met ALL the specifications.
However, it is your tractor and you can install whatever you want.
Old 02-27-2014, 06:33 PM
Shrewcub's Avatar
I can back up what Roland says. I cut open all of my filters. I double checked the Wix site, a 51084 is listed as a lube/ trans filter, while the correct 51410 is a hydraulic filter. And they are quality filters, perhaps better than the Cub filter I just took off of my 1864.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 02-27-2014, 06:42 PM
I use NAPA 1410's on all of my Cubs Wix # is 51410, wix makes the filters for NAPA just remove the first digit # 5 for the NAPA number.
