Old 02-27-2014, 08:42 PM
Well now I'm confused. If you go to the Wix filter lookup it looks like anything built before the 982 uses the 51084 and after the 51410. Both have the same micron and gpm rating but the 51084 has a by-pass, maybe that's a bad thing IDK. I have never used anything but a 51410 and was just stating what another well respected Cub aficionado stated and that is backed up by Wix's site. Did anything change in the pumps or is it the oil that caused the change? I'm pretty sure that either filter would work fine for the 2 gallons of oil they filter.
Old 02-27-2014, 09:16 PM
gmbadgley gmbadgley is offline
Wix makes NAPA filters, just drop the first # of the Wix# for the NAPA #.
You can make your self crazy trying to figure out the differences in filters, If the threads, Gaskets & Micron ratings are the same it should work just fine.
The new tier 4 diesels use fuel filters that will not cross, the only place to find them is the Original manufacturer.
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 02-28-2014, 09:07 AM
bill682 bill682 is offline
The Sundstrand Service Manual states that the filter should not have a by-pass.
I guess the Wix lookup is wrong because the 51084 has a by-pass.
Old 02-28-2014, 09:47 AM
When you go to the Wix Website and you cross reference Part Number 723-3014, it only comes up with one Wix Number, that being 51410.
Old 04-01-2019, 11:18 PM
Rodster Rodster is offline
Old topic I know but just wanted to say Thanks to all the folks who provide this valuable information!
