Old 03-03-2014, 11:49 AM
Dave R Dave R is offline
Default 3 point hitch
I would like to fabricate a 3 point hitch for my 149. I think I can make one that will work, however, I need to know the length of the lift bar, and how far back from the front the slight bend is made. I plan to make the with a piece of pipe and weld the lift arm on it. I have the installation instruction as outlined in a brochure but there are no dimensions on anything.
I can cut the rod that extends through the frame and put a pipe sleeve over it and then weld the lift lever and another pipe to hold the protruding left piece onto it.
Anyone with some dimensions would sure be appreciated.
Dave in SW Missouri
Old 03-03-2014, 12:02 PM
cjrolke cjrolke is offline
I have looked in to doing something like that but ended up buying everything because it was easier than trying to reinvent the wheel on average I believe I have around $70 in each of my 3points I have added to 4 tractors
Old 03-03-2014, 12:07 PM
Default 3 point
There are several on Ebay now, they start at $150 up, then the sleeve hitch is about that much more.
dlr
Old 03-03-2014, 12:59 PM
Berwil's Avatar
Berwil Berwil is offline
Try this thread
http://www.onlycubcadets.net/forum/s...tch+dimensions
Bill
Old 03-03-2014, 01:07 PM
Dave in SW Missouri
Do you want a Cat 0, or a sleeve hitch?
Here is a thread for a NF, with dimensions.......NF 3 point.
Here is athread for a Cat 0...... Cat 0 on a 1450
Or, get a hold of Patton, he's has a little better price than E-Bay. Bottom line, if you want stuff, it costs money. And, from my experience, it's usually cheaper to buy, than like stated before, trying to "reinvent the wheel". It's really not that much money.
Old 03-03-2014, 07:09 PM
dlr
My heavy duty sleeve hitch with one pair of lift straps is $115 shipped
Here's the parts I make http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Jeff
