Old 02-21-2014, 08:27 AM
Dremel's Avatar
Dremel Dremel is offline
I have a QA42 and a QA36 that sit on pallets. I've never used them in favor of just a blade, weights and chains. I tried hooking up the 42 and it lasted about 2 seconds before the chain went flying off the sprocket in to the snow and it sounded like it was waiting to kill me. I probably didn't have things adjusted correctly.
Like you we've gotten many feet of snow in the last 2 months. I usually go for the JD 2 stage walk behind blower then go around and clean up with the 149/blade.
Thanks for the inspiration to perhaps give the QA's another try.
B
Old 02-21-2014, 09:41 AM
rdehli rdehli is offline
Lew
Nice looking unit. Got more snow headed your way. Heads up we got more last night.....
Old 02-21-2014, 08:56 PM
Looks good Lew
Nothing like a hydro for snow removal, you can always get the perfect speed.
I'm loving the hydraulic lift on the 125 I got from you. Makes lifting the QA42 easy. The WF PTO I put on yesterday works great too. Locks up great and drags the motor down burying the QA42 in the wet snow
https://www.youtube.com/watch?v=tfWy8jbj_GY
Works great, Thanks Lew
Old 02-22-2014, 07:29 PM
Flatbedford's Avatar
I was at work through most of the first big snow this season. I came home to about 9" of wet snow. My 149 with the blade was pretty much useless. The snow was so heavy that with the blade angled, the tractor went sideways and with the blade straight I could only push about 10' until the pile weighed more than the tractor and all forward progress stopped. My other 149 with the QA42A did fine as long as I took smaller bites and didn't go too fast. It would have been miserable if I wasn't on a hydro with hydro lift. These singe stage throwers are much better than most people say they are. You just have to learn how to use 'em.
Steve,
Former multiple 149 owner.
Old 02-22-2014, 08:56 PM
PaulS's Avatar
PaulS PaulS is offline
I have to agree on those old snow throwers. I used one for many years. I had a 54" haban on my big 2084 and that snow pushed me around even with the super. I took that off and put my 451 two stage on and had no more trouble unless the snow was blown before or was coming over the top then the belt started to squeal and I backed up fast.
Old 03-04-2014, 06:25 PM
Thanks Guys,
The last time I used this I heard a chirping sound coming from the motor so today I checked to see if the head gasket was blown.It was and it must have just happened as there was no oil residue on the fins or on the head.
Cleaned up the carbon,and flattened the head,checked the bore and it still has the cross hatch marks from it still being a newer replacement motor and all.
Gave a run for 15 minutes and will re-torque the bolts tomorrow.
Bring on some snow!!!
Up to 534 and counting...
Old 03-04-2014, 06:28 PM
Very nice work lew as always. New head bolts and all. That is a clean valve.
Old 03-04-2014, 06:35 PM
Yes it is,Nick
and yes I have been to Ray's
Old 03-04-2014, 07:12 PM
Looks good Lewis!
Old 03-04-2014, 08:17 PM
Yes it is,Nick
Yes Lewis.
