Old 03-07-2014, 06:35 PM
Cool Pulley puller
I made this funny PTO basket puller today out of an old drive shaft, some longer basket pulley set screws and a sledge hammer head. It worked fine. Alternated the puller from one screw to the other. I put the Allen head of the screws into the holes in case it broke off so I can get it out later. I may change the set screws to non hardened ones though.
Don't forget your safety glasses!!!
Please comment if you please.
Up to 534 and counting...
Old 03-07-2014, 07:04 PM
Way to use your noggin Lew!
Old 03-07-2014, 07:11 PM
I used the puller not my head!
BTW this was soaking for 2 days in PB so it kinda helped.
Old 03-07-2014, 07:18 PM
Old 03-07-2014, 07:52 PM
Nice "master of invention" idea Lew
I like KROIL better than PB or LW.
Did you leave the PTO arm in place? I could make a piece for the driveshaft to slip over the threaded collar so the basket pulley would be driven straight off.
I used a different approach to get my pulley off.
I made a puller and drilled the pulley for 5/16-18NC ( "F" drill ) The spacing also works for removing the flywheel.
By using two longer bolts with 1/2" sockets, it makes a great PTO bearing puller
Old 03-07-2014, 07:53 PM
Good idea lew, I could have used that idea 2 weeks ago, would have saved me a basket pulley!
Old 03-07-2014, 07:58 PM
[QUOTE=darkminion_17;247508]I made this funny PTO basket puller today out of an old drive shaft,
Must have been the driveshaft out of my 149 We picked up from u a few months back!
Old 03-07-2014, 08:20 PM
Anything that Gits Er Done is a good thing, way to go Buddy!
I would have used the fire wrench and probably cooked the engine.
Old 03-07-2014, 08:24 PM
cubcadet;247527
Yes it was Nick.
Jeff,
I would like to see if you can make a collar to fit over the part of the pulley that has the set screws, then drill 2 holes in it that would line up the the ones on the pulley, put a threaded end on the collar to fit on a real slide hammer.sorta something like that...
There are different sizes of bushings on the pto baskets though,so you would have to get at least the two sizes I have seen.
Old 03-07-2014, 08:38 PM
Good thinking Lew
So.... now if we want to make one, do we just get the drive shafts from Nick?
