#21
#22
How about an extended shaft, and a second lift handle on the other side? Manual lift with manual assist.
Philip 1450, 1015, and a pile of parts. |
#23
![]() Quote:
![]() Quote:
![]() I do not believe in disking!! ![]() ![]() |
#25
He has some serious wheel weights on that tractor.
I don't use my Cub. I just work on it and look at it. So far it's holding up very well. |
#26
![]() Quote:
![]() Your more of a conservation tillage guy aren't you...... ? I don't see you do much tillage at all. |
#27
![]() Quote:
That pretty smell of untouched soil is the fungus; "Tillage Conventional tillage and other soil disturbance has a negative impact on VAM function. It breaks up fungal threads in soil and destroys their connections with the plant so that they cannot work to increase uptake of nutrients." http://soilwater.com.au/bettersoils/module4/4_3.htm I just like to minimize tillage, a quick break of the top inch so I can get the seeds is is my method. I think running a tiller like a TroyBilt between the rows kills the fungus and helps control weeds, a good thing. Kinda like natural herbicide! ![]() For me, M I N I M U M tillage ![]() Now, if the weeds are out of control, you gotta do what you gotta do! ![]() ![]() |
#28
[QUOTE=J-Mech;248161]LOL! I used to have that! 480 and a 1066 has to be one of the best combinations out there!
When I did some farm work many years back, I turned many an acre with the 1066/480 combo. Couple of years, ran a 1466 with the biggest 480.... Maybe 22 or 24 feet wide with the longest extension gangs... I don't remember the exact size of that 480, but it was a huge honkin' disk. For even heavier duty disk work, the farm had a 500 disk. I think that thing could disk up concrete.
Only thing better than having a Cub Cadet is USING one ![]() ![]() |
#29
IMHO running a disk over plowed ground, only to run after it with a tiller is wasted time and fuel. Or more seat time which is prolly why allot of people do it. Lol
#30
Or..... because it smooths it up and fills in the dead furrows. The tiller won't till level when it isn't working on level soil.
