Old 03-02-2014, 12:16 PM
All I got is a homemade POS:
Maybe some day I can afford store-bought!
Old 03-02-2014, 01:01 PM
Or at least some paint for those GREEN weights!
Old 03-02-2014, 07:55 PM
What is the recommended color?
New Holland blue?
Old 03-02-2014, 08:04 PM
New Holland blue?
Big John
Good to see you back. I did miss you buddy.
Old 03-03-2014, 08:06 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Here's the one I built for my 1650 tiller setup couple years ago.. It incorporates the mule drive into the design
Also comes in handy to carry all the rocks you dredge up while tilling>
I like that!
I lost track of what I own a long time ago!
Old 03-30-2014, 04:45 PM
rockyj82 rockyj82 is offline
Default Can you guess what these were in a former life?
So here is the front weight bracket that my father and I came up with. We originally needed one to keep the front of the tractor down when plowing some virgin ground although it is great at keeping the front end where you put it when pushing snow also. It is tucked in to the grill enough that it doesnt interfere with the lift of the snow plow. As for what they were in a former life. they are a stack of weights off of a nautilus weight machine like you would find in a gym. The weights are 10 pound each and the box is about 10 pound giving a total of 100 pounds of extra weight on the front. Hope you guys like it!!
1450 Cub hydro sleeve hitch
50a Mower Deck
42" Snow Blade
Single Bottom Plow
42" Snow Thrower
Old 03-30-2014, 07:40 PM
Old 03-30-2014, 08:42 PM
Nice job!
Old 03-31-2014, 01:41 AM
Looks like a lot of weight to hang on the lower grill casting, but hey, if your happy, I'm happy.
Old 04-01-2014, 11:47 AM
actually no weight at all on the casting, the box has two 1/2" bolts welded in it that go through the front frame and then large flat washers and lock nuts on the other side of the frame. Thanks for the lookout though!!!
50a Mower Deck
42" Snow Blade
Single Bottom Plow
42" Snow Thrower
