Old 04-02-2014, 09:02 PM
Originally Posted by sawdustdad View Post
Thanks for the words of encouragement. I am confident this will be one of my favorite tractors when I get done. It's just going to take more time. And as the weather warms (it was 75 here today, all the trees are blooming) shop time gets scarce as yard work increases...I'll get there one way or the other.
Are you thinking what I'm thinking..........Of course you are!! .....Remote Controlled Cubs!!!
Old 04-03-2014, 07:40 AM
sawdustdad's Avatar
replacement carb on order. I have a pile (three actually) of spare carbs but they are all for pre-QL tractors--wrong choke arm. Wondering? Can you swap this from one carb to the other? In other words, convert a 108 carb to work on the 1000. Can this be done?
I looked at the after market carbs that were on ebay a few weeks ago and that were the subject of a couple threads in the kohler engine forum, but they are no longer available. bought a used carb instead.
I'm seriously considering pulling the engine and rebuilding it now.
Old 04-03-2014, 11:12 PM
sawdustdad's Avatar
Answered my own question. Yes you can swap choke shafts from a QL carb to a non-QL carb. Just moved the shaft from my 1000's carb to a carb off a 108. works fine. Won't get a chance to install it until Sunday, but looks like this might work.
Old 04-04-2014, 12:10 AM
Sounds good, glad the swap worked Cheaper also
Old 04-04-2014, 02:37 AM
cubby102's Avatar
cubby102 cubby102 is offline
The shaft swaps work fine. Ive done it to just about every quietline that I put a kohler/carter carb on that had a walbro. Iirc I even swapped between the two. Can't remember
Old 04-04-2014, 07:52 AM
mickb72 mickb72 is offline
Default carb
Hi Cubby, wish you could remember. I need to do this, swap a choke shaft between a kohler and a walbro. Can it be done. Thanks Mike
Old 04-04-2014, 12:32 PM
snoel's Avatar
snoel snoel is offline
Default Old newbe
Old codger here, with a newly acquired 149. It's a good looking old tractor. Runs great, but with some maintenance / repair issues.
So, I just found this thread, and read it all the way through. Great information, that will be a continual reference, for my own work. I greatly appreciate the step-by-step progress report with pictures. I am an ex-mechanic/welder/fab/ cobbler. But new to the CC world of rejuvenate. I had one of the O's (nearly worn out) many years ago, but did not try to restore it.
Thanks,
Steve
Old 04-04-2014, 12:52 PM
Thanks,
Steve
Welcome to OCC Steve!
Old 04-04-2014, 08:55 PM
sawdustdad's Avatar
Thanks,
Steve
Hi, Steve, welcome to OCC! I have a 149, too, and they are great tractors. (the one on the far left in my signature pic with the ags on front). When you get around to working on your 149 you should be able to find several 149 restoration threads here. Everyone is very helpful, I've learned a bunch from the folks here.
Old 04-06-2014, 08:02 PM
sawdustdad's Avatar
I put another carb on the 1000 and while it ran better, it's clear that the governor isn't working. It overspeeds and does not respond to the throttle as expected (won't return to idle) I'm still getting fire out the exhaust, so either it needs a valve job or the exhaust valve is sticking. The engine is coming out of the tractor and will be overhauled. Stay tuned for what I find as I disassemble this engine.
