Old 04-17-2014, 09:21 AM
Default Getting the 800 ready for grass cutting!
Hey guys,
I am getting ready to put the deck on the 800, I want to put something on the bottom of the deck to protect it, what should I use , primer, paint, or undercoating? Thanks.
Old 04-17-2014, 10:42 AM
Berwil's Avatar
Berwil Berwil is offline
When it's rusty like that I like to brush on rust converter. It chemically changes the rust into a black hard coating that you can paint over. I can't remember the name of it. You can leave just the converter or follow up with primer and paint, I've done both with similar results. Next spring...repeat, nothing lasts long under there.
Bill
Old 04-17-2014, 10:59 AM
Bill
Ok, I have already started to prep it, would the hardware store have that rust converter?
Old 04-17-2014, 11:38 AM
You could try POR-15 or Chassis Saver Nick.
Old 04-17-2014, 11:39 AM
Berwil's Avatar
Ok, I have already starter to prep it, would the hardware store have that rust converter?
I'm pretty sure they will, tractor supply has Rust Kutter brand, HD, Ace, and lowes should have it as well. It's a liquid in a bottle, not an aerosol. I believe it's basically phosphoric acid. I don't remember the brand I used, someone gave it to me but it worked well.
Old 04-17-2014, 12:01 PM
Ok thanks mike.
Old 04-17-2014, 12:02 PM
Ok thanks bill.
Old 04-17-2014, 03:19 PM
Guys,
My local hardware store had a little bottle of rust converter for $10.99, didn't want to pay that, so sitting right next to it was the same stuff in a spray can for $5.99, so I got that and the deck and blades came out good.
Old 04-17-2014, 03:21 PM
How's it look?
Old 04-17-2014, 03:59 PM
Got the threads oiled up and the blades installed.
