Old 04-11-2010, 02:45 PM
dan dan is offline
Default hydro check valve?
Can these valves be fixed/unstuck? I only had rev, swapped the valves and the problem followed, I had fwd and no rev. Which valve is fwd? Is there something I can do to free it up?
Old 04-12-2010, 07:53 AM
Dan:
YES...the Hydro Check Valves can get gummed up, clogged with foreign debris, and just wear out.
Remove the valves, place them in a "penetrating solution" for a while, clean them out, blow them out real good, and check for free movement. If you are confident that you done all you can, re-install them and check out the operation.
If all went well, then things should be back to normal. If not, then Check Valve replacement is probably needed.
Here is some further information.... Check Valves
Old 04-12-2010, 09:00 AM
The new prices were $57.02 from L.G. Fluid power,
that I received last week.
Still a lot less expensive than from cub cadet.
Old 04-12-2010, 08:54 PM
Mountain Heritage's Avatar
Okay...so these ones your talking about...they are good for the IH built 82 series as well???
Updated price from Cub Cadet in Canada.....$192.94 Each!! Can you OUCH!!
Any suggestions?
Did anyone ever ask these guys in Illinois if they will ship to Canada or take an order over the phone with a VISA??
Old 04-12-2010, 09:07 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Any suggestions?
You might check ebay, I bought some for about $35.
Pat Benner Haskell OK
Old 04-12-2010, 09:26 PM
MH:
YUP....those Check Valves are the same for the 82 Series.
Old 04-12-2010, 10:16 PM
Any suggestions?
LG will take visa orders over the phone, but not Discover.
At least that is how I paid for my last two orders.
They have old style and new style, new style # is LJ-9500085.
They are in Delton Michigan (near Grand Rapids) I don't know if they ship to Canada but I would think so.
If you purchase the valves from John Deere Vs. cub cadet, they are less expensive but not much.
The valves from L.G are new valves, not used or rebuilt or ebay questionable.
I might add I have no interest in L.G Fluid Power, just passing along my experience with them.
Old 04-13-2010, 05:56 AM
Thanks! I have the fluid here from IH....got that and a filter both. Got home and realized I needed a rear cover gasket in order to change the oil though. So I am waiting to grab that later this week. Also cleaned a corner of the bench off....realized I had a hydro filter here already. Guy I bought the tractor from gave me one....DUH! Well, I guess I will not need one for a while now, just have to remember to look for it in the cupboard next time I want to change it!
I think I will try giving them a call today and see if they will ship to Canada. Certainly a lot cheaper if they do - even if they send it pony express!
Right now I have the manual release type in the tractor.....do I automatically replace them with the same? Or is it better to have the automatic type???? What is the benifits of each? Anyone care to take a stab at this one?
Old 04-13-2010, 06:31 AM
The manual Check Valves will be replaced by the Automatic Type.
Old 04-13-2010, 07:06 AM
Ok, dumb question....why would they go to manual over the automatic? It seems everything in the world is going to automatic?
