Old 04-30-2014, 06:45 PM
john hall's Avatar
I think when I bumped the starter it must have been enough torque to snap the mounting tab. So...... out came the engine. I would like to give the designer of all this engine tin a kick in the butt,, holy smoke, it takes longer to remove all that crap than pull the engine.
The IH dealer dad worked for was also a Kohler dealer, they got to see too many of the exploding KT engines. The time Kohler would allow to completely tear an engine down to fix it under warranty was not near enough so they had to eat a bunch of the labor bill. One of their biggest gripes was the sheet metal. One particular engine that kept showing up with the guts tore up was on a 2 blade concrete finisher that you rode. After the second or third time they figured out the owner was over revving the engine. They set it at the proper speed and marked/documented every screw and linkage on the machine. Told the guy if he ever brought it back he'd have to pay up front, no more warranties. They never heard from him again. As for the Kohler rep, he heard more than an earful about their warranty policies from the dealerships owner.
Old 05-01-2014, 08:01 PM
Sent the engine off today with a local welder, fabricator, machinist, and he figured it wouldn't be a problem fixing.
Find out next week.
Old 05-01-2014, 10:20 PM
Find out next week.
Hope all works out, Todd!
Old 05-02-2014, 12:50 AM
Old 05-02-2014, 06:41 AM
Hope it works out for you Todd!
Old 05-06-2014, 08:29 PM
Got the engine back today. Right back to factory specs. Shure isn't a lot of materiel between the outside and the bolt hole though. Top mount isn't any better, should be ok with both nuts tight now
Also got the mounting shoulder bolt nut welded back in seeing the engine is out.
Old 05-06-2014, 10:06 PM
Nice repair, Todd! You'll have the 782 going in no time!
Old 05-06-2014, 10:10 PM
Glad to see you got it fixed Todd!
Old 05-06-2014, 10:12 PM
Thanks guys, should know in the next day or two. Lot more work installing these than the old K series.
Old 05-07-2014, 06:27 AM
Well done, weld looks good.
