Old 05-20-2014, 09:29 PM
Dgregg Dgregg is offline
Default 44C deck on a 149
I'd like to put a 44C deck on a 149CC, what am I going to have to change or do? Will it go on as is?
Thanks
David
Old 05-20-2014, 09:30 PM
JLM78 JLM78 is offline
what do you have under now ?
Old 05-20-2014, 09:36 PM
you will A 44 or 50 inch Deck carriage
Old 05-20-2014, 09:40 PM
Nothing, this CC came without a deck. But I have the carriage and mule drive for a 44A that came with another 149 but the deck is not very good shape.
The 44C came with a 1450 and I have the mule drive and carriage that came with it.
The center dive pulley on the 44C deck is for a wider belt than was used on the 149, or will the skinnier belt work on the wide pulley, just set down in the groove farther?
Old 05-20-2014, 09:46 PM
it will go right under it. May be the drive pully need swich
Old 05-20-2014, 09:47 PM
Got the carriage, what about the widder drive pulley on the center spindle?
Old 05-20-2014, 09:48 PM
you need to put the 3/8 pully on it
Old 05-20-2014, 09:52 PM
OK that is what I figured. Going to take the one off of the 44A and see if it will work then.
Thanks
david
Old 05-20-2014, 09:56 PM
I just did the same Thing to one for A 128 cub
Old 05-21-2014, 11:56 AM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Although it would be correct to swap the pulleys, I have been running a 44c on a 108 for about 3 years without changing the pulleys. I have not had any abnormal belt wear.
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
