Old 05-26-2014, 06:27 PM
Bob95065 Bob95065 is offline
Default K series Timing - can you do it real-time?
I set the timing on my 1450 engine using a meter when I had it on the bench out of the tractor. I put it back and and used a timing light to check the timing. It is slightly off. Is it safe to adjust the points with the engine running? Any tricks that will make it easier?
Old 05-26-2014, 09:32 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
you can set them with it running. best bet is to tighten the crew just enough that you can still slide the points to adjust them. when you get it where you want then just lock it down
