HI everyone,
I need some ideas on getting the flywheel off my engine. I have used penetrating oil on it for four days and have tried using a puller each day, but it still won't break free. What advice can you give me on getting it off the shaft? Gene |
Tighten the puller tight, and hit the pull bolt with a hammer. Like a 2-3lb hammer, not a dinky 16 ouncer.
put the nut on the crank till its flush on the end. set up your puller and tighten down the yoke screw as tight as you can. then whack the head of the yoke screw with a decent size hammer. should pop right off. when I refer to the yoke screw that is the center bolt of your puller
guess our timing and thought process was about the same. now I'm scared
Thanks for the advice, but still no movement. I flattened out the head of the puller bolt with ten good hits. I just wanted to remove it and the backing plate to paint the block. Guess I'll just do some masking since it really doesn't need to come off.
look in at the keyway and make sure the key isn't sheared.
only other thing is put heat on the flywheel with the puller on and repeat the steps with the puller and hammer. |
The key looks fine. I wondered about heating, but all I have is a propane torch. I'll give that a try tomorrow. I had good luck with all the other parts that usually stick; guess I couldn't have all the luck tearing it down.
