Old 06-01-2014, 05:27 PM
Rocketman65 Rocketman65 is offline
Default 2166 Intermittent Cut-Off
First Posting
Hello
I have 2166, 16hp Kohler Command, Shaft Drive, 42" deck.
This thing mows great under load until it gets 'hotter' and then just goes dead and won't start until it gets good and ready to.
One time it was the next day before it started again.
Things I have done to it is:
Cleaned Carb.
Checked fuel system. (getting plenty of fuel)
Checked for spark immediately when it cut off. (got spark)
Good compression.
I suspect the coil or something connected to the Ignition system.
If anyone can help.
Please
Thanks
Rocketman65
Old 06-01-2014, 05:39 PM
Welcome to OCC! Sounds like it may be time for a new ignition module. The one on my wife's 2130 went out this weekend.
Old 06-02-2014, 07:33 AM
If you have spark when it shuts off I'd be more inclined to suspect a fuel problem. Just my 2 cents but I would replace all of the fuel line from the tank to the engine. I've seen it collapse when it get's old. Also check the insulation around the fuel line in the engine compartment. If the fuel is getting hot enough it can vapor lock. Your fuel pump may also be getting tired. These things get HOT under the hood you may try running it with the side panels off.
