Old 03-25-2014, 01:38 PM
The foam looks like the correct stuff from what I see. If I recall it's about 2"X2" with adhesive on one side.
Old 03-25-2014, 01:53 PM
jimbob200521's Avatar
I believe you're right. I wish I had taken some pics of it when I had the motor out of my 1811 to compare to. After 24+ years in there, it can be expected to look a little disfigurd
-Ryan
Old 03-25-2014, 11:55 PM
inspectorudy's Avatar
My advice is to ditch the belt cover on the deck when you get it running again. I just finished rebuilding two JD decks and they were almost pristine on the outside but looked like the surface of the moon on the inside. Those belt covers create a compost in your deck and it will eat that steel like a french fry. Paint'em up and put'em away for when you sell it. It tells you something when the outside of a deck which gets the rain and sun all year long looks great but the inside that is "Protected" all year looks like a pizza pie!
1811 Hydro
Old 04-20-2014, 10:54 AM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Not much to report as I'm rounding up engine parts. I found a crankcase, two jugs, and camshaft from a low hour M18. Still trying to find a local machine shop to turn the crank.I'm really bummed at the lack of machine shops in my area that will do small engine work Boy is buying M18 parts an eye and wallet opening experience!
We tightened up the front axle and installed two new rib tires I had for another project. Those new tires make that 1811 look plum sexy even without a hood or engine,lol. I bought the filter, Hytrans and gasket to change the hydro fluid so that is here. I'm going to order the brake material this week to reline the brakes so it looks like we have plenty to do.
I had planned on just getting the thing running but the machine is so straight and complete it begs for more. I have a new HVLP paint gun at work and my son's project and a bus to paint so I might just strip the 1811 down and haul it to work as well. These things tend to get out of hand
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 06-02-2014, 02:57 PM
RR1862CC's Avatar
Well it is taking a while but I'm still moving forward on the 1811 as time and money permit.
We got the sheet metal off down to the frame and found a frame repair the PO had done. It looks like at one time there was a three point or some other hitch on it and the left side mount hole for the rear end had cracked and wallowed out. The PO had booger welded some big flat washers over the frame to fix it and it looks like crap! I found out the 1050 I found in the junkyard uses the same frame so I bought it for $25 and will be stripping/painting it and switching everything over from the 1811..
Yesterday I tore the deck apart and found two of three spindle bearings good but after sitting 15 years with all that crud under the belt cover I will have to replace all three pulleys and the idler pulley. I only found two small pin holes in the deck under the belt cover so that was great news. Last week I got new metal cut and hope to start this week making the new baffles for under the deck if time permits.
The engine is still on the bench waiting for the funds for the rebuild.
This is the third of three major restorations I'm doing besides my regular job two garden tractors and a car. If anybody ever finds that elusive money tree send me some seeds or a sprout to start my own
Allis Chalmers 416
Brinly 10"plow
Old 06-02-2014, 03:21 PM
You bought the whole tractor for $25? Or just the frame?
Old 06-02-2014, 06:27 PM
RR1862CC's Avatar
Frame,steering colum,front axle, and both rear tires and wheels. I'm thinking about seeing what they want for the hood,grill shell and rear axle just to have spare parts. Or if I could find the rear sheet metal take my old frame and the other parts and add one of the engines I have sitting around. Kinda like a Franken Cub
Allis Chalmers 416
Brinly 10"plow
Old 06-02-2014, 10:20 PM
Thanks for the update.
