Old 06-06-2014, 03:13 PM
Well the disk has seen better days but I think it will last the summer. I showed the owner so he knows it's tired.
When I'm 83 I want Nick to fix my Cubs also.
Same here.
Old 06-06-2014, 03:24 PM
jimbob200521's Avatar
Just a random question; why does it only have one tire chain on it?
Good looking machine, and double good on you for helping out a friend
-Ryan
Old 06-06-2014, 03:48 PM
I hope when I am 83 Nick will come over and fix my cubs for me....
Old 06-06-2014, 06:51 PM
Well this thing is rapidly turning into the Cub from hell. It has a dead hole in the engine. Gotta see what the owner wants to do with it. Looks like it has an issue with an intake valve. Will know more after I pull the head. Why do I get myself involved in these messes is beyond me. If I was even 1/2 way smart I would stay away. Cocktail hour so don't bother me, talk to you guys tomorrow.
Old 06-06-2014, 09:13 PM
No idea why it only had 1 tire chain on it. Also found the kill wire had been eaten by the mice. Just shoot me now. If this was my tractor I'd have the cutting torch out and fired up.
Old 06-06-2014, 09:32 PM
Sam,
Mice see the yellow and think "cheese"
sent you an email about the briggs manual
Up to 534 and counting...
Old 06-06-2014, 09:41 PM
Sam,
Lew you are the best, I don't care what Nick say's.
Mice seem to like B&S stuff the most. Gotta post a pic of the wire I took out of this thing. The nest is in my shop vac. At least it was not in the blower shroud, pulled the tins and all good inside.
Old 06-06-2014, 09:51 PM
I would have sent you the book,but a pdf will work.
Old 06-07-2014, 08:38 AM
mickb72 mickb72 is offline
Default cub
I had one of those 16 briggs that the valve spring seat had eaten into the alum block. The lash was alright and still functioned. Mike
Old 06-07-2014, 06:21 PM
Got the old turd running. Bad head gasket, but the engine is pretty well used up as is the clutch. Had to re-build his "Good deck" Yeah love it when someone leaves the spacer between the spindle bearings out. Sharpened the blades put them back on and couldn't turn the spindle, seals were in upside down, idler pulley seized up solid and on and on and on. It runs, it cuts grass. I did what I told him I would do. Big thanks to all of you that have helped in this project. Give yourselves a pat on the back.
