I know nothing about painting do i need to take it down to bare metal or can i paint over the old paint. And if i take it down to bare matal what kind of primer do i need. Can sombody help me.
No Cub124. You do not need to take it down to bare metal. Just sand it really good and if there is rust spots that are uneven then put some putty to smooth it out. i use heavy truck primer,sand it,then non sanding primer before we shoot color. Check out my 108 in my albums. we restored it and didnt take it to bare metal. it turned out great.
Cubmonkey - I would guess that even sanding may not remove all of the petroleum that may be on the paint. Do you ever degrease the areas you want to paint? What do you recommend? The reason I am asking is that my engine bay is really cruddy and sanding every nook and cranny is going to be a tough job.
Go to your local auto parts store (Not Autoshack) and get (Not sure if this is spelled right or not) "Pre-cleano", (use as directed)
Cub 124 Some members clean old paint with oven cleaner. After your sure its clean, clean with wax & grease cleaner from any auto paint store. Do this before you sand as sanding will rub wax & grease in the old paint and cause you problems with new paint. Best of luck with your paint job JMD
Cub124 Its Wax & Grease Remover not cleaner sorry had a Brain F---. JMD
I have used primer thinned to about half of what it should have been and got a primer "shell" that was thick and about rock hard. Not easy to sand, but one pass did it.
weaverama. Yes i use a degreaser mixture on it before i pressure wash them i degrease the engine bay and the rearend.
