Old 06-14-2014, 08:33 AM
Sugarmaker's Avatar
Todd,
Getting that 125 up in the air will help. Your going to be doing some serious work on the front end to get the new narrow front end mounted. I will be watching.
I know its a lot of work but are you considering and clean up and paint for the 125? Dash tower looks to be in pretty good shape.
(My open utility trailer project fell through, leaves me more time to work on tractors I guess)
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 06-14-2014, 10:07 PM
Got the rest of the re-paint stripped off today. Looks better already.
No Chris, no painting, that ended with the 100, my first and only
Old 06-14-2014, 10:23 PM
Keep up the good work, Todd!
Old 06-15-2014, 11:07 AM
Looking good Todd! Looking forward to the narrow front!
Old 06-15-2014, 09:04 PM
OK, having a dilemma here.
I need to replace the O-rings in these two center housing plugs. I took the skid plate off and need to loosen up the suction tube to move it off to the side.
I DO NOT want to split this tractor, and see no reason if I get the tube off to the side far enough.
Question is. Is there anything special I need to know once I get the tubes disconnected. Fluid has been drained. To reconnect, just wrap the threads with plumbers tape?
Thanks
Old 06-15-2014, 11:47 PM
Thanks
NO TAPE! Just replace the O-rings and your good to go. The o-ring seals it. If any tape gets in right there...... not good. Besides, it's a waste. The plug threads aren't tapered (pipe thread), so tape wouldn't help anyway.
I don't see any reason to spit the tractor. Like you said, just pull the pipe so you can get to it, pull the plugs, spin a new o-ring on, and good to go! Oh, on the fitting for the pipe..... no tape their either. They use a feral. No tape needed.
Old 06-16-2014, 01:14 AM
Thank you very much my friend
Old 06-16-2014, 07:32 AM
Sugarmaker's Avatar
Todd,
Learning about oil leaks from you guys this morning. You are good at finding these types of problems I usually find them aft the tractor is complete
The paint removal and diss assembly look good. Gives me ideas if i want to take my 125 apart some day.
Are you sure you can get away with making this a narrow front end and not painting it??? There could be some type of state law that forces you to do it!
Regards,
Chris
Old 06-16-2014, 01:32 PM
Todd,
Regards,
Chris
Thanks Chris, but I'm passing on the painting thing.
Got an idea. You should hook up the 250 to the "new" mobile home and take a ride over and paint it for me.
If nothing else we could have a good B.S. session.
Old 06-16-2014, 09:11 PM
Got some more done on the 125 today.
Pulled the steering off today to get things ready for the narrow front.
Big surprise, dirty, dirty, dirty.
