Old 06-16-2014, 08:43 AM
340demon's Avatar
340demon 340demon is offline
Default Valve stems on inside of rims
Anyone ever see this style rims before? Bought a 102 for parts and when we got to looking at the rims, the valve stem holes are on the backside. They have the hump by the stem hole so they are not just drilled. Ok my father said maybe something to do with wheel weights . But have weights on my rims and no issues same size rims. They look like they are turned inside out but the raised surface ring inside bolt circle says different? Any clues I'm guessing different make than cub? Ok just never saw this before. I will try to put pics up this evening. Not letting me upload from phone. Ok thanks for any input!
Sam
My Cubs
108 & 1250 & 104
Tiller, snow thrower,
Plow
Old 06-16-2014, 09:07 AM
Different make. I have purchased a couple cubs with this and the stems actually rub on the brakes if you have external brakes. JD rims are like this
Old 06-16-2014, 09:33 AM
TheSaturnV's Avatar
They could also be Sears Suburban/David Bradley type rims. If you can find really short valve stems, they may clear the brakes.
Old 06-16-2014, 09:39 AM
The older cubs with internal brakes had the valve stem on the backside of the wheel and the valve stem was moved to the front when external brakes came out. the hump tells me its not a cub wheel but I have seen something like what you describe on a jd my friend has but im not sure there even original to that tractor as I know nothing about green tractors.
Old 06-16-2014, 10:22 AM
340demon's Avatar
Thanks guys we had never seen this style before. There is a slight hump right above the hole and looks similar to a cub. Never heard about early cubs being backwards can u elaborate on that? Father has a 70 and a 73 both on the outside, that's why we were wondering? I will post some pics this evening, they have tubes in them now. Nothing wrong with them just was strange when we saw them on the inside. Thanks for the info. What was the reasoning for the higher box under seat and steering tower? We compared to his 70 and 73 and frame looks identical except for said higher box and fenders of course. Is this the whole reason so they could use same chassis for the 14-16hp models too? But trans looks the same height as earlier models? Ok sorry had to ask!
Sam
My Cubs
108 & 1250 & 104
Plow
Old 06-16-2014, 10:46 AM
As far as im aware all internal brake cubs came from the factory with the valve stem on the inside which is the way alot of older farm tractors were, when cub went to external brakes they put the valve stem on the outside because the valve stem would hit the brakes. If that info is incorrect someone please chime in.
Old 06-16-2014, 10:58 AM
red56turbo's Avatar
Cubs came from the factory with valve stems on the outside. If they are on the inside, they are from another manufacturer. Wheel weights were made with a notch in them to allow for valve stem clearance.
Josh
Diesel Cub Cadets...........
Old 06-16-2014, 01:23 PM
340demon's Avatar
Ok thanks I was really starting to wonder! Cause I have seen 70's with stems on the outside haven't ran into an original yet but assumed they where outside on all? Thanks guys!
Sam
My Cubs
108 & 1250 & 104
Plow
Old 06-16-2014, 01:40 PM
I second that statement.
Up to 534 and counting...
Old 06-16-2014, 02:08 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
One front wheel on my 102 has the stem on the inside. Guess I need to find a wheel as I am fixing it up
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
