Old 06-17-2014, 12:50 AM
Way to go Sam, push a button and up it goes
Old 06-17-2014, 06:29 AM
Originally Posted by ivel03 View Post
Sam,
Nice work. I hope you get some videos of you running it with the power lift.
I've kinda been keeping my eye out for a sickle mower and noticed this:
http://fingerlakes.craigslist.org/grd/4495049517.html
Any ideas how hard it would be to put that on a 2072? I know you didn't put it on a super but you did mount one on a tractor that wasn't designed for it. This price seems a bit high but i've not seen many come up for sale. Also I can't figure out what the differences between an 402D and 402E are?
Thanks,
-Levi
Levi
TIMCRUTCHER put one on a 1782
I was hoping to see the Sickle Bar modified to be a hedge trimmer , but was not disappointed to see your mod. Great job engineering that Sam!! Looks like your haul that day was a day well spent, providing new projects and idea for you. Glad you got it set up nicely.
It will cut vertical so it will be trimming a couple pine trees along my driveway.
I'm all about power.
Old 06-17-2014, 06:38 AM
Looks good Sam!
Old 06-17-2014, 09:37 AM
JLM78 JLM78 is offline
On A stock set up how many mounting points is their ? just the front axle And rear mount ?
Old 06-17-2014, 09:44 AM
jimbob200521's Avatar
Looking great, Sam! Can't wait to see it in action
-Ryan
Old 06-17-2014, 03:41 PM
Yep just the front axle and the rear mount. I couldn't mount to the axle because of the way it is on a Cyclops. Got it running today the hyd and winch lift's are way cool! Still need to do a little tweaking.
Old 06-17-2014, 07:47 PM
TIMCRUTCHER TIMCRUTCHER is offline
My biggest concern was vibration. That may very well be because I mounted it to the tractor frame very rigid.
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 06-18-2014, 12:30 PM
Made a little mod to the mower today that reduced the shake a bunch. I added some counter weight to the left side. Just happened to have some leftover lead weights from my old race car and some box tube. So I built an arm that sticks out on the left and bolted the weights to it. This took most of the twist out of the tractor and I think the increased mass dampens most of the shake. Thought it was going to rip the tractor apart it shook so bad.
Old 06-18-2014, 02:05 PM
Nice work on the mod, Sam.
Old 06-18-2014, 02:16 PM
X2!
