Old 06-22-2014, 12:54 PM
Userj8670's Avatar
Default Want to install different air cleaner
Want to put a 169 style air cleaner on my 126. I know the parts are put there but was curious if anyone has done this yet?
P.s. I did try the search but had no luck
Old 06-22-2014, 01:41 PM
Just use one off of a KT or a Mag. They're the same, except they don't have the extra holes in the side. (Which you don't need.)
Old 06-22-2014, 04:03 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
yep, We were doing that 20+ years ago. like J-Mech suggested the KT style works to as do the old cast iron K series twins
Old 06-22-2014, 06:56 PM
Userj8670's Avatar
Any advantage to running these?
Old 06-22-2014, 07:02 PM
dvogtvpe's Avatar
none what so ever if everything else is stock. waste of time and money but I suppose the cool factor is there
Old 06-22-2014, 08:04 PM
Sure there is..... You don't have to clean the air filter as often!
Old 06-22-2014, 08:24 PM
dvogtvpe's Avatar
get the K&N replacement then you never have to replace it
Old 06-22-2014, 09:16 PM
Userj8670's Avatar
Have you done this mod yourself?
Old 06-23-2014, 12:52 AM
Put a bigger air cleaner on? No. Why? Like we said, it doesn't gain anything. If your wanting to know if it bolts up, or will work, yes. But I don't do it. Not on a stock engine. Now, if I was going to up the HP.... (internal engine work) then yeah, I would. If your looking for HP, then it's not going to do anything.
Old 06-23-2014, 05:19 PM
Userj8670's Avatar
Is there anything that I could do for this k301 to wake it up while keeping it reliable and mower friendly?
