Old 06-23-2014, 02:02 PM
It is more difficult to do on a NF, but it's all there is and has to be done and as mentioned above it can only be done on a tractor that is fully functional.
What is a little scary is the that the adjustment point is located in such a spot that in order to see/get to it, you gotta have the tractor raised and your head right there in front of the spinning tire. If I'm not mistaken it takes a 9/16" socket a 6" extension and a ratchet.
IIRC, loosen the bolts to the point where the bracket will slide (with some resistance) under the heads of the bolts. you can use a hammer and punch to tap the bracket up and you can use a large screwdriver to "pry" it down, I think you can get the blade of the screwdriver between the bracket and the head of the top bolt and twist the screwdriver (kinda like adjusting points).
I think one of the big things is, to make sure you have all of the other work done first... That way you only have to do it once.
FWIW, if you are dealing with a tractor that has much if any wear on the related parts, I don't think it is possible to get it adjusted perfectly. When you pull the lever back and push the pedal down, then push the lever forward and push the pedal down it almost always ends up in two different places. In a situation like this I always try to "split the difference" and call it good.
If this is your first time, you may want to choose a time when things are very calm and relaxed in the surrounding area of where you are working and that there are little or no distractions. If you stay calm, be patient and take your time, the job will go much smother and the end result will be much better.
Good luck.
Edit: Now that I think about it, Cub-n-bxrs is probably right about the heads of the bolts being 12 point, I'll also bet that the 12 point bolts are 7/16" or 1/2" and NOT 9/16" as I said earlier.
Old 06-23-2014, 03:45 PM
Thanks, this was what I was hoping someone would help me answer. I can picture it now and that's what i needed, coupled with the service manual I should be good.
Old 06-23-2014, 08:49 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
WOW!! I guess that the manual does not explain THAT part. I did manage to get to a pc and downloaded the necasary pages but NONE of them explained where the bolts were. Thank you gentlemen for the rest of the story!
Old 06-23-2014, 09:04 PM
The manual tells where the bolts are..... Are you guys reading the same manual that I am?
Old 06-23-2014, 09:14 PM
Apparently not. I downloaded the service AND hydro manual and neither one shows the correct location of the bolts. The manual shows the bolts on TOP of the rear assy., not the bottom. The hydro manual shows the same.
Old 06-23-2014, 09:22 PM
Description on how to adjust the hydro is on page 2-55. It references you to the illustration #2-45 on page 2-42, where it clearly shows the bolts you need to loosen.
Old 06-23-2014, 11:21 PM
I just came in from welding a trunion, while I was there I checked the bolts... 3/8" 12 point.
Wow am I getting old!
Old 06-24-2014, 11:20 AM
That's what they all have.......
Old 06-24-2014, 11:42 AM
cubs-n-bxrs's Avatar
Believe I mentioned that. LOL
Old 06-25-2014, 10:55 AM
sawdustdad's Avatar
I'm pretty sure the neutral adjust bolts on all my WF tractors are 9/16. There is a pair of 3/8 12pt bolts on the hydro, but those do not hold the cam plate. Is the NF different? (never messed with my 123's hydro.)
