Old 06-30-2014, 08:11 AM
SGragg SGragg is offline
Inactive Member
Default Faulty Fuel Pump - Again
Mower's been running well after changing points (for about a month) until I tried starting it Friday evening. Cranked well, but wouldn't catch. Pulled air filter housing off and could see brown liquid sitting on base of filter housing. Cranked again and saw brownish fluid sputtering up from the hose connecting the crankcase. My first thought: fuel pump is leaking gas into the engine.
It was time for a mid-season oil change anyway, so the next morning I pulled the dipstick and it was way up over the level of where it was the previous week. Drained oil and it gushed out and smelled of gas. Bummer!
Thought I was hosed for mowing, but wait! I remembered bypassing the fuel pump when I had this trouble earlier. So, got a straight piece of fuel line and bypassed the pump, filled up the crankcase with SAE-30 oil and filled the gas tank and she fired right up. Mowed for the next 1-1/2 hours w/o a problem.
Thanks to suggestions on this forum I was able to keep going instead of being stuck. And whoever said something on here about Stens fuel pumps being crap, I now believe them.
I may just keep the bypass and make sure the gas tank is over the half-full mark.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 06-30-2014, 08:35 AM
mickb72 mickb72 is offline
Default cub
Hello, i just bypassed one too. Mag 18 in my 582 has a new clean looking fuel pump. Hasn't been used much but i kept getting that rising oil level. I have gas shutoffs on all my tractors and use them, so it must be leaking while running. 2 oil changes into the firepit! May go electric. Mike
Old 06-30-2014, 09:00 AM
Shaner Shaner is offline
I put a vaccum style pump on off an 1862 and it pumps fuel great. I bought one of those stems pumps and it felt cheesy. The push lock fuel fittings are a stupid design with that snap ring to hold the tabs in so it will lock together. I put mine together, mounted it and turned the fuel on and it started to flow from both fittings down the side of the block. I tried to take it out and reset the fittings but noticed the fuel pump body itself was cracked....so I threw it in the garbage where it belongs. Kohler brand or vacuum or gravity only!
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 06-30-2014, 09:10 AM
jimbob200521's Avatar
That may have been me I remember posting to someone that they are an option, but that the one I had, died out in mere months. I'm with you, however; if I have one go out on one of my Mag's, I will go gravity since I try not to run my tanks too low. That, or pony up for a Kohler brand
-Ryan
Old 06-30-2014, 09:20 AM
You could use something like this.
http://www.summitracing.com/parts/pfs-10701/overview/
Old 06-30-2014, 10:31 AM
So, you tried to start your tractor without first checking the oil? If you had done that like you should always do, it wouldn't have required pulling the air filter. Good thing it didn't start, or this may have been a "why did my motor lock up" thread.
Old 06-30-2014, 12:59 PM
Inactive Member
Since owning this machine and knowing it uses a little oil, I'm familiar to its rate of use. Got in the habit of checking it every other mow.
You're spot on J-Mech. Now I'll be checking it before each use. Good advice.
Stanton
