Old 06-30-2014, 10:25 AM
johnc johnc is offline
Default Choke cable stuck on 2145
My HDS 2145 serial # 290 290 choke cable frozen
Would wd 40 work or should I use a different oil?
Also is there a best way to remove cable?
Thanks,
John
Old 06-30-2014, 10:27 AM
Yes, WD-40 or replace the cable.
Nothing special, it's just like changing any other choke cable.
Old 06-30-2014, 11:09 AM
782CC 782CC is offline
I use a cable lube for motorcycles. There is a tool just for doing cables. It can do different size sheaths. Grommet has steps in it. Yours may already be beyond saving if stuck. But might help with future cable maintenance.
Hope this link works. Not promoting this one in particular. I use cable life and like it very much. But there are many out there.
http://www.aerostich.com/cable-luber-lube-kit.html
Old 06-30-2014, 02:17 PM
Jon
The 2000 series cables have a funky snap in mount on the dash unlike normal cables.
I used Power Blaster on one that was stuck.
I agree with the MC cable lube.
Old 06-30-2014, 02:54 PM
Jon
My bad. I've changed them before, but I guess I don't remember the snap ring..... Maybe it had been replaced before. IDK. Maybe it wasn't a 2145 either.
Old 06-30-2014, 03:07 PM
No snap ring, they are plastic and push into a square hole in the dash. Crappy design.
Old 06-30-2014, 03:25 PM
YES! Oh, yeah.... I remember that. Those are a PITA!
