Old 07-06-2014, 06:36 PM
I just put in all studs on my manual lift 125. I'm not playing that game again
Not a bad way to go. Only bad part is if you ever pull it again, it makes cleaning the gasket surface hard.
Old 07-06-2014, 06:39 PM
I cleaned the threads with a tap and used anti seize ( copper based ) on the ends of the studs.
Old 07-06-2014, 06:45 PM
So they will come out nice and easy. I always use that on head bolts. At 35ftlbs, I doubt it affects torque.
Old 07-06-2014, 07:40 PM
If you can id go with j mechs suggestion, ive used that same technique several times over the years with good results.
Old 07-06-2014, 08:33 PM
Just reading this makes me think of how many different ways over the years I've got broken stuff out. Sure some of you guys may know about this but have you ever seen a broken tap extractor? I have a set and they are the most unused yet completely necessary tools out there. Long fingers with a collar that slides down them to squeeze the broken tap and back it out. I've actually run across broken taps in things from other people leaving them in and gotten them out.
Jeff commented on another thread about using a t handle on a tap instead of a wrench or adjustable to "just clean threads". And yes, I have broken a tap before just cleaning threads because you never know when you fracture one the time before because they are so hard. Try getting one out or drilling them, you will not enjoy life.
Old 07-06-2014, 08:52 PM
Tap extractors are nice, really nothing worse to deal with than a broken drill bit or tap.
Old 07-06-2014, 10:47 PM
Unless you do what I did the other day...... then they don't even work.
Shoulda been here. It was fun!
Old 07-06-2014, 10:49 PM
did you brake the tap extractor off? been there before.
Old 07-06-2014, 11:00 PM
Nope. Broke a tap. Had a broken exhaust manifold bolt break on a 6.0 chevy gas. (Like a million of them are.) Front on the left head. Took my right angle drill and drilled it. It's a M8 bolt, hardened, and lock-tite'd in. Drilled out the bolt, and went to tap the threads. Got about halfway down the hole, and suddenly got tight. Then SNAP!....
Loooooong story short. Pulled the head. Tried to mill it out. Couldn't. Tried everything. It was stuck. Chipped out what I could. Drove it to the bottom of the hole. Heli-coiled it, and cut the new bolt off short. Hole was deep enough that the entire heli-coil went it, so it was all good. The new bolt was in contact with all the threads that it could. Storal of the morey, (let's see who gets that reference)..... weld a washer and nut to them and pull them. That's how I usually do it, but it was up there next to the temp sensor and I didn't want to drain the coolant, plus it was hard to get to. 4hr job, turned 4 days.
Old 07-16-2014, 11:18 AM
1650noob 1650noob is offline
Had time to take the head off today. Some of the head bolts were lose. And the sheared bolt is flush with the block. I was hoping maybe some of the thread would protrude so I could get some vise grips on it. But the easy way won't be happening. The head doesn't look too bad just light carbon build up. The gasket on the other hand was broken and degraded.
Owner of:
cub 1650
cub 122
