Old 07-18-2014, 11:00 PM
OldCubby OldCubby is offline
Default Wanted: #26 carb for a 1250
The head on my main throttle shaft busted off leaving the threaded part in the main shaft. So, I need some help. Either a carb or the main throttle shaft with butterfly and screws.
Thanks.
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 07-21-2014, 02:28 PM
rick57 rick57 is offline
Default carb
If you have a part number for the carb I might be able to help you out
Rick
Old 07-21-2014, 02:55 PM
Rick
Why do you need a part number for a #26 carb?
Old 07-21-2014, 05:34 PM
Why can't you just drill out the broken screw and re-tap the shaft?
Old 07-21-2014, 05:38 PM
Just for reference you can. If it is the butterfly screw he's talking about.
Here's the reference part. They are a #3-48 screw. Nobody keeps them. I have a box that I ordered from McMaster Carr. Brass screw. Also had to order a tap from them as it's so small nobody keeps a tap. Not even my local machine shop had one smaller than a #4. They are brass screws and drill easy...... if they're original.
Old 07-23-2014, 02:32 PM
Because his ad said "Wanted Carb" so if he wants a new one I would need the part number.
Old 08-05-2014, 12:52 AM
Rdrnek Rdrnek is offline
You sound like the guys at the small engine shop I go to to buy Kohler parts.
whats a #26 carb?? it has a 26 stamped in the throat of the carb. If it has that you should be in business.
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
