Old 07-26-2014, 12:29 AM
gdheck's Avatar
gdheck gdheck is offline
Default Hydraulic flow of supers?
Does anyone know the average flow rate of the hydraulics on a Cub Cadet, specifically on a SGT? I want to know what size of hydraulic motor I can run with the front ports on my 2072. It would just be intermittent use, like to turn the chute on my blower, run a wire winder, etc. Yes, I'm getting lazy, but a knee injury at the ripe old age of 30 that kept me from work this whole week has got me to thinking about the future.
Thanks,
Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 07-26-2014, 01:15 AM
Not quite even 5 GPM at WOT.
Old 07-26-2014, 01:20 AM
gdheck's Avatar
Just what I needed. Thanks!
Old 07-26-2014, 01:26 AM
Suggestion:
Use an electric motor for the blower chute. It's WAAAAAYYYYY cheaper, and easier to install.
Also, I don't know what all you are wanting to do with an orbital motor, but remember, these only have 600-900PSI max, so it isn't going to do much...... And not fast at that low of GPM.
Old 07-26-2014, 02:21 AM
gdheck's Avatar
I already have some small hydraulic motors. The rest is just a right angle bracket, a sprocket on the hyd. motor, hoses, chain and adding a sprocket to the chute in a way that won't destroy the original parts. I also have my own machine shop to do the work in.
Yes, before anyone else gets ideas, it would normally be pretty expensive if you had to buy new hydraulic motors.
Old 07-26-2014, 09:30 PM
messary messary is offline
Not sure what blower/ thrower your using, but I can send you a pic of how I mounted the hyd motor on my qa42a. It works great and is easy to do. All you need is a #40 sprocket and to fab a bracket. I can't post pic until I get home tomorrow though if it helps. My only problem is I got rid of the 1650 and bought a 2072. Now I have to figure out how to mount the qa42a on a super
Old 07-27-2014, 01:06 AM
gdheck's Avatar
I would like to see a picture of the mount. It never hurts to get other ideas.
Old 07-27-2014, 06:25 AM
Best pic I have. I drilled to holes for the front side and used a longer stud through the mounting hole for the guard over the shaft and sprocket. No problems at all, and it got a LOT of use last winter. I added a flow control to one hose to slow it down, but it would have been ok without it. Turns pretty slow when it's really cold until the fluid warms up. I dig it.
Old 07-27-2014, 06:39 AM
It worked fine when buried in snow and ice after a couple hours of moving drifts taller than the cub.
Old 07-27-2014, 12:21 PM
wow that is cool,
Up to 534 and counting...
