Old 08-03-2014, 12:32 AM
CHESTERSCUBSC CHESTERSCUBSC is offline
Default Cub Cadet Original Toggle Switch Queston
Is the on position up or down on the switch
Old 08-03-2014, 01:29 AM
Originals had a a key switch, not a toggle.
Old 08-03-2014, 08:14 AM
How about a picture of this "toggle switch".
Old 08-03-2014, 08:20 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
My original came with a toggle that will be changed ASAP to the proper keyswitch. On mine when the switch is up it is on. Take a meter or test light and connect it from ground to the positive side of the coil. Then try the switch. When the switch is on, you will have power to the coil. On mine the starter button will turn the starter no matter what position the switch is in. The switch only turns power on and off to the positive side of the coil.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 08-03-2014, 07:46 PM
Thanks will give the meter a try tomorrow.
