So occasionally I need to bend some metal or possibly break free a fastener, but I don't need heat enough to warrant the purchase of an acetylene rig. Will a map gas torch get hot enough to do what I need? You know, the ones like the propane torches, except with a yellow tank. ( I think )
For the similar applications I had, a map gas torch works great. Also, as a paint prep tool.
Interesting topic, I will be following this.
So, to bend something as say a lift rod for a front blade, a propane torch won't get hot enough?
-Ryan
A mapp gas torch doesn't get any hotter than a propane. If you guys need to heat metal to the point of "red hot" you will have to get a mapp/propane/acetylene; oxygen combo torch. Mix any of those 3 gasses with oxygen and it is the same result. Propane and Mapp gas are just less volatile gasses and thus considered "safer".
Like I said, it's supposed to be a little "safer" of a gas. It's also supposed to be a little cheaper. Mapp VS Propane, not much difference at all. Couple degrees hotter. Not really any "benefit" at all AFAIC. I've used all the gasses. Propane, Mapp, Acetylene torches. I'll keep my acetylene. It's way hotter of a fire.
If your really curious, google it. Here's a link that has a temp chart: http://www.engineeringtoolbox.com/fl...ses-d_422.html **NOTE: the temps are in Celsius** |
Mapp is hotter.
Mapp does burn hotter than propane which also makes it cheaper to use because less gas is required... but propane can be used for small jobs also. Acetylene can be used without oxygen and is hotter than Mapp but it requires an expensive regulator and torch tip.
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
I use mapp gas with a benzomatic self ignition turbo tip. It works good. Home depot has them or used to.
