Old 08-13-2014, 09:59 AM
bschmittling bschmittling is offline
A neighbor came by over the weekend and made a good offer on my 122 junker so I am going to sell it to him. That will leave me with my restored 124 to work with. It doesn't need much to get on the track. I already have a pulling hitch and wheelie bars.
Since I actually use this cub on weekends to move dirt and stuff on a piece of land I am clearing, I can't afford to have it break down. So, the plan now is to rebuild the clutch with a 6 pin driver, hardened drive shaft, and red spring. The stock driver will be converted to 6 pin. It will still be essentially stock so it may slide. While I am doing that, I will go ahead and install the fine splined axles and carrier I bought a while back. The worst that can happen is they move me up to the garden modified class.
Old 08-13-2014, 08:33 PM
GrotenhuisCubs's Avatar
GrotenhuisCubs GrotenhuisCubs is offline
Default Not necessary
I don't think the six pin driver and fine splines are necessary at all! I would agree with a red spring but I think your spending money that doesn't need to be spent. Been pulling a 104 for three years now with a red spring and a 10% overdrive and doing real well. Governor get your governor set right and you will do well! Most people don't know how to set a governor at all for pulling! My two cents!
104 puller, 1200 puller, 1450 toy!
Old 08-13-2014, 08:51 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
or have the "good" governor weight assembly
Old 08-13-2014, 09:08 PM
Just move the spring down to the last hole to get more rpm! Lol
Old 08-13-2014, 09:27 PM
dvogtvpe's Avatar
and then reset the stop so its at 3800. there is a setup I like to use that when they tack you it will read 3800 , 4000 or whatever. but when you get going down the track it raise's 200 rpm . there's also another setup I like to use that makes the governor very sensitive to any amount of load.
Old 08-14-2014, 08:02 AM
I actually like third or so hole up and get as much stretch on the governor spring as I can. It's the best when the tractor sounds horrible until 3/4 of the way down the track and then the governor takes over!
Old 08-14-2014, 11:04 AM
Do you use a pulling hitch or the stock hitch?
Old 08-14-2014, 01:44 PM
I build a pulling hitch that is adjustable, angle iron 1 piece of flat stock, and some 5/8 ready rod. Easy to build if I get a chance I will snap a pic
Old 08-14-2014, 02:07 PM
dvogtvpe's Avatar
we did that back in the early 80's, then we got serious and figured some stuff out that wrks much better
Old 08-14-2014, 09:51 PM
Inform us Don, I would like to hear about it!
