Old 08-20-2014, 08:52 AM
jimbob200521's Avatar
Default Haban blade question
For those that have had had Haban blade, are there different mounting packages for different Super's? I've got a line on a Haban that was installed on a 2072 and 1872 with the current owner, but I'd want to put it on a 2284. Would I need anything, or should it be a simple swap?
-Ryan
Old 08-20-2014, 08:55 AM
You probably need something different for the lift, the rock shafts are different between the older Supers and the 2284. I think this may work for a Haban blade, Xtreme makes it.
File Type: jpg Cub%20Cadet%20Lift%20Bracket%20719-3097.jpg (5.5 KB, 88 views)
Old 08-20-2014, 10:32 AM
Just for the lift, similar to the bracket you posted? Otherwise, it should mount up, correct?
PS Did someone move this to LT? I thought I posted it in Implements
-Ryan
Old 08-20-2014, 10:59 AM
I don't know, but either way it doesn't go in the LT section. I moved it to the implement section.
Old 08-20-2014, 11:25 AM
red56turbo's Avatar
Ryan,
It should bolt right up as far as the subframe goes. I've got one on the 1772 right now. The frame and quick attach should be the same from 1872/2072 to the cyclops supers. Sam is probably right on the lift mechanism. IDK about that off the top of my head. I've never tried to put the blade on the 1782.
Josh
Diesel Cub Cadets...........
