Old 08-21-2014, 05:00 PM
nikster's Avatar
nikster nikster is offline
Default This should NOT be? Something is wrong?
The # 2185 was getting harder & harder to start? Took off the air cleaner & what a shock.
Something is wrong, BUT WHAT?
Nik,
Crud all over the carb
& housing wiped clean.
Old 08-21-2014, 05:25 PM
jimbob200521's Avatar
I have to ask, and I doubt it's a no, buutt....have you cleaned it since you got it?!!? I've never seen one that bad
Edit: Something isn't right. In your second pic, there is visible grass and debris by your carb opening indicating it's getting past the filter. Was it maybe cocked last time you installed it and it didn't seat right? Something has to be asmis if that much is getting past the filter.
-Ryan
Old 08-21-2014, 05:46 PM
Nik,
Check the rotary screen on the back of the motor. Is it missing/damaged?
Air is fed into the filter housing from the blower housing. The flywheel fan sucks the air in, then directs it across the motor for cooling, and some goes into the air filter housing. FWIW, you should probably pull all engine tins and clean the motor out. It will also be full of grass.
I'm sure you know, but make sure you get all the grass off the top of that carb opening. There is still a lot sitting there.
Old 08-21-2014, 06:05 PM
Its not winter so I don't think your air filter needs a coat.
Old 08-21-2014, 09:07 PM
nikster's Avatar
Nik,
The rotary screen is there & intact.
It was clean when I replaced the coils (22hrs. ago)
Got to take a closer look.
Nik
Old 08-21-2014, 10:41 PM
ccpullin ccpullin is offline
I would suspect a mouse is making a home in your blower housing by the size of the clippings, then when started the fan blows it in the air filter. Notice the grass clippings behind the head shroud also.
Old 08-21-2014, 11:33 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I don't think your breather hose is seated properly. Try gently pulling up on it. The red sealing spacer looks squished too. That's probably how it's getting past the filter. Check the grass screen and pull the tins.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-22-2014, 06:50 AM
j knight j knight is offline
Nik,
MOUSE found a penthouse
Old 08-22-2014, 08:17 AM
nikster's Avatar
Going to check that out?
I'll also take everything off, tins etc. & slowly check EVERYTHING & go from there. put everything back- make a cut & see what happens?
Gonna see if I can find another 2000 series in my area, compare it to mine & then see also?
Nik,
Old 08-22-2014, 08:34 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
You haven't inadvertently connected the chute from the deck to the air intake on the air cleaner have you?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
