Old 08-19-2014, 11:43 PM
Originally Posted by Mr Bob View Post
Tim,
What brand fluid do you use from Tractor Supply?
Bob
this is the fluid i used most recently in a 123, according to the description its compatible with the case/ih hytrans. i dont have much run time on it but the trans acts much better than it did with the old fluid and filter.
http://www.tractorsupply.com/en/stor...on-fluid-2-gal
Old 08-20-2014, 12:14 AM
kostendorf's Avatar
Just another story on Hydro fluid but I think it might do some good here. when I purchased my 1650 3 years ago I used this fluid from TSC and it made an immediate difference in noise and power. I was happy. one year later it started making a little noise again in neutral. It stayed like this till this year I bought a tiller and had to put the gear box on the rear which meant I was going to have to put a new gasket on it and drain the fluid. it was clean and just a little darker than when I put it in but I don't believe this fluid will last 20 years like the IH Hytran has done in so many machines out there. So I just bit the bullet and put the good stuff in and I'm sure its going to be in there for longer than 3 years.
Old 08-20-2014, 12:43 AM
if its like anything else you should probably change the fluid more often than every 20 years, realistically the fluid and filter should be replaced once a year.
Old 08-20-2014, 01:35 AM
kostendorf's Avatar
I totally agree. But I might have put 4 hours on mine this year so far. I see post all the time of people cleaning out who knows how old oil out of these hydro rear ends.
Old 08-20-2014, 10:41 AM
rwairforce rwairforce is offline
I'm no oil expert but I would think change intervals would have to consider amount of actual use. I have Cubs sitting in a garage or shed for 5 years, I doubt the hydro oil would need changed. I may be incorrect with my thinking but I don't change it when its been sitting in a sealed rear end doing nothing.
I just pulled my 1440 apart and it was as clean as new snow inside and it probably had 400 hours on the hydro change and had been sitting the past 3 years.
The oil saga will continue for years after we're all gone. That keeps things lively I suppose. When you think about it, depending on your age, you might as well give all your hydros one more "good stuff" oil change because it will probably out live you....
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-24-2014, 01:20 PM
Wing Bucket Wing Bucket is offline
Took a while, but here we go. Couple pics of the 149 and the deck and plow that came with it.....
Latest bit of work was putting tubes in the front tires. With that plus the filters I've changed, I can called this "restored" now, right?
Red 782 hydro with deck and front plow
Nothing like saving the day with something you didn't throw away!
