Old 08-14-2014, 09:07 PM
LOL! Yes Daniel, your blade is now worth exactly $7.38 less that it was before.
haha
Old 08-19-2014, 06:45 PM
Beer Belly's Avatar
Beer Belly Beer Belly is offline
I have cleaned many old "Griswold" Erie, PA & "Wagner" Sidney, O, cast iron frying pans in the past. Straight vinegar works wonders on the rust, Easy-Off oven cleaner on grunge. Never tried it on a tractor, but.....
The American way: Accrue massive amounts of debt on things we cannot afford. Simultaneously giving the illusion of owning great sums of money for the sole purpose of impressing those around you.
---Beerbelly 2014
Old 08-21-2014, 08:00 PM
yeeter yeeter is offline
I have a plastic container (maybe a pretzel container) with a screw on lid, filled with a rust remover solution. I dont remember the brand, but likely not much different than the molasses concoction. When taking things apart I just throw them all in there and leave it sit a few days.
The rate at which I get projects done this is fine. And they are all in one place.
Otherwise I just swap them out new.
Old 08-24-2014, 09:30 AM
Hand_108 Hand_108 is offline
Inactive Member
Originally Posted by cc_bob View Post
Not quick but very cheap and EASY, just mix up some molasses and water and let them sit for a week. It won't remove the plating or grease but it will remove all of the rust.
Details here..
http://www.onlycubcadets.net/forum/s...ad.php?t=26163
Molasses works AWESOME!!!! But it does take a long time. I used a 50gal plastic trash can and did a bunch of stuff to test it. My "tank" sat out side about 6+ months, froze, thawed, froze, thawed. Started it in Oct and pulled stuff out April-May. Was AMAZED!!!! And I would do it again in a second!!!
Old 08-24-2014, 12:33 PM
cc_bob cc_bob is offline
Glad to hear someone else has tried this.
The warmer it is outside the better it works. I usually leave stuff in for a week, take it out and pressure wash it, and put it in for another week. After the second week it's usually completely rust free. I haven't tried it in the winter, afraid my tank would split if it froze.
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 08-24-2014, 08:26 PM
Inactive Member
Yes, I hear it works better when warmer. I was not thinking about that when I did it. I just wanted to do it. I kind of forgot about it and then next thing I knew it was winter and it was frozen solid. I wasnt worried about it splitting as it was sitting outside by my garage. If it did, it would have been no worse than when I dumped it out. What I want to get is one of those BIG 250 gallon totes on a pallet with the wire around it with a drain on the bottom and try even bigger parts. And a 2nd one for an electrolis tank. But if I do, it will be started early March and not pulled untill Oct. The wheels I did were BAD and they came out looking really good. Longer they sit, better/cleaner/rust removed they will be. Most of my projects are never "gotta get it done now" projects, so sitting for 6+ months to soak/derust is no biggie to me.
Glad to hear im not the only crazy one out there...heheheheeh
John
Old 08-24-2014, 08:48 PM
Leadslingingdaddy's Avatar
My time is worth too much money to take the time to clean a bolt that can be replaced for such small cost. I understand that some people want the IH headed bolt, but so far.... I have never seen a case where it made a difference on the value of the machine, or won more trophy's for having the original hardware. (On a Cub Cadet) If you know of a case where it did matter, I'll bow out of that statement.
What he said!
Old 08-24-2014, 09:33 PM
////Wise N. Heimer mode on
I use gasoline...about a half gallon in my car to drive to and from my local hardware store...
////Wise N. Heimer mode off
Only thing better than having a Cub Cadet is USING one
Tags
bolts, cadet, original, suggestions, tractor
